Can't find rear window gasket/seal, 76 renovation |
DaveBruen |
Jun 14 2018, 05:11 AM
Newbie Group: Members Posts: 3 Joined: 14-February 18 From: Brewster, NY Member No.: 21,890 Region Association: North East States |
Looking for help locating the gasket that seats the rear window in my 914. Went to Pelican and Autohaus. No luck locating this part. Any suggestions?
Dave |
jdamiano |
Jun 14 2018, 05:42 AM
Member Group: Members Posts: 335 Joined: 18-March 18 From: Jacksonville Member No.: 21,981 Region Association: South East States |
You use butyl tape for that. I forgot the size. I got mine from Amazon and reused the little rubber spacers. 914Rubber will hook you up with what you need. http://www.914rubber.com
Mikey914 |
Jun 14 2018, 08:53 AM
The rubber man Group: Members Posts: 12,638 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Yes, it's not technically a gasket, but butyl rubber. Don't forget to put in the rubber setting blocks as they keep the glass off the metal.
Also if you are careful you might get the old one out in pretty much one piece. This makes cleaning the opening much easier. Just did mine and put in the dark tinted glass. Attached thumbnail(s) |
Mikey914 |
Jun 14 2018, 08:54 AM
Removed
Lo-Fi Version | Time is now: 19th April 2024 - 05:53 PM |
