gas cap gasket, source and fill question |
Abeck914 |
Jun 14 2018, 10:22 AM
Newbie Group: Members Posts: 25 Joined: 4-December 17 From: Rhode Island Member No.: 21,677 Region Association: None |
Hi all,
I checked a bunch of things and got rid of most of my gas vapor smell [opened up nipple in overflow cup, blew through the overflow line, pulled the breather hose straight and down 1/2", refilled charcoal canister, checked fuel pump, replaced filler neck gasket]. that solved 95% of my vapor smell. but when i drive adventurously I am still getting smell on turns. fair enough, its gas cap gasket time. So, where are you guys buying gaskets from? The only parts listing that I feel comfortable with after reading online is 914rubber. But I can't say I enjoy paying $15 shipping for a $5 gasket. Any other recommendations? I've tried some VW sources and they don't seem to have the correct ID and OD, close but a little off. And, I guess while we are on this topic. How did you guys fill your tanks? I was reading on the Samba that they are all putting the nozzle all the way in and filling until click. which isn't giving them a full tank. Interested in hearing how you guys are doing it since I assumed I knew how to fill a gas tank (IMG:style_emoticons/default/confused24.gif) Thanks, Aaron |
TheCabinetmaker |
Jun 14 2018, 10:30 AM
There should be a plastic guard inside the filler that will only let you put the gas nozzle in so far.
Matty900 |
Jun 14 2018, 10:36 AM
Senior Member Group: Members Posts: 1,269 Joined: 21-February 15 From: Oregon Member No.: 18,454 Region Association: Pacific Northwest |
Hi all, I checked a bunch of things and got rid of most of my gas vapor smell [opened up nipple in overflow cup, blew through the overflow line, pulled the breather hose straight and down 1/2", refilled charcoal canister, checked fuel pump, replaced filler neck gasket]. that solved 95% of my vapor smell. but when i drive adventurously I am still getting smell on turns. fair enough, its gas cap gasket time. So, where are you guys buying gaskets from? The only parts listing that I feel comfortable with after reading online is 914rubber. But I can't say I enjoy paying $15 shipping for a $5 gasket. Any other recommendations? I've tried some VW sources and they don't seem to have the correct ID and OD, close but a little off. And, I guess while we are on this topic. How did you guys fill your tanks? I was reading on the Samba that they are all putting the nozzle all the way in and filling until click. which isn't giving them a full tank. Interested in hearing how you guys are doing it since I assumed I knew how to fill a gas tank (IMG:style_emoticons/default/confused24.gif) Thanks, Aaron Hi Aaron, I think you're probably right about it being the seal. 914rubber will get you the correct shipping charge on that, just having issues with the site calculating shipping correctly. Hope to have that fixed on the new site by the end of the month. Just been busy getting my car done for West Coast Rally. (I am down dealing with this on my car right now but it is because I have a small leak we believe from a crack near the nipple on the bottom so the tank will come out Saturday) You can always choose "print and call" at checkout if your not sure about something in your order like shipping charges, and Scott will reach out to you to complete the order. (IMG:style_emoticons/default/beerchug.gif) Matt Whitesell 914 Rubber Attached thumbnail(s) |
Lo-Fi Version | Time is now: 25th April 2024 - 10:15 PM |
