2.0 engine #, Engine identity |
Morph914 |
Jun 14 2018, 12:15 PM
Member Group: Members Posts: 435 Joined: 22-August 16 From: St Augustine, FL Member No.: 20,326 Region Association: South East States |
I am looking at a 2.0 on eBay, it is supposedly out of a '75. The # stamped on the block is GC003297, all the other 2.0 engines I've seen start with GA. Any help to decipher this is appreciated.
Thanks, John |
ValcoOscar |
Jun 14 2018, 12:22 PM
Garage Life Group: Members Posts: 2,378 Joined: 19-November 13 From: SoCal Member No.: 16,669 Region Association: Southern California |
I'm told...
GC engines are out of 75-76 914 2.0L with 7.6 to 1 CR, heads have the air injection ports which can be filled with 10mm valve adjuster screws. 95 hp engine if set up right. |
Dave_Darling |
Jun 14 2018, 12:27 PM
914 Idiot Group: Members Posts: 14,981 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
GA == 73-74 US-spec 2.0
GB == 73-74 RoW-spec 2.0 GC == 75-76 US-spec 2.0 The GC made 88 HP (DIN) as opposed to 95 HP (DIN) from the GA motors. The primary difference was the exhaust, which was pretty awful on the late cars. The GB made 100 HP (DIN), primarily due to higher compression. --DD |
Tom_T |
Jun 14 2018, 02:32 PM
GA == 73-74 US-spec 2.0 GB == 73-74 RoW-spec 2.0 GC == 75-76 US-spec 2.0 The GC made 88 HP (DIN) as opposed to 95 HP (DIN) from the GA motors. The primary difference was the exhaust, which was pretty awful on the late cars. The GB made 100 HP (DIN), primarily due to higher compression. --DD (IMG:style_emoticons/default/agree.gif) Dave's got it there for you. Although I'm trying to find the documentation for where the California 75-76 GC only made about 80-84 HP that I remember from when I test drove them new back in the day. Also, you can put Euro P&Cs on any GA & do the requisite EFI adjustments for 100 HP for an easy power bump, as was commonly done back in the day. I'm not sure if the GC can be built &/or tweaked to make 95 HP, but if it's a 76 it may not pass CA smog required on them still every other year. Bottom line, the GC code is correct for the one you're looking at, but don't bank on anything conditionwise without driving it in a car, or running it on a stand & doung all of the compression & leak-down etc. tests - otherwise it's just a core which may or may not be usable pending tear down. (IMG:style_emoticons/default/beerchug.gif) Tom ///////. |
KELTY360 |
Jun 14 2018, 03:10 PM
914 Neferati Group: Members Posts: 5,031 Joined: 31-December 05 From: Pt. Townsend, WA Member No.: 5,344 Region Association: Pacific Northwest |
Where is that number located?
Dave_Darling |
Jun 14 2018, 03:36 PM
In front of the oil filler tower, on the 2.0 914 engines. See the arrow near the center of the pic below:
(IMG:http://www.914world.com/bbs2/uploads_offsite/www.pelicanparts.com-121-1529012209.1.JPG) Some VW applications also have engine serial numbers there. The other 914 engines, and many VW ones, have codes elsewhere. Primarily on top of the right half of the case (upper-left of the photo). I bet the "80 HP" that others have noted for the GC motors is measured SAE Net. DIN uses a different set of test conditions, and typically reads higher than SAE Net. SAE Gross is an older measurement that reads even higher for the same engine than DIN does. --DD |
KELTY360 |
Jun 14 2018, 03:56 PM
Thanks Dave. I have to admit, I was too lazy to search. (IMG:style_emoticons/default/slap.gif)
Morph914 |
Jun 14 2018, 08:22 PM
Thank you all for the input, I really appreciate it! I think I'll hold out for a GA engine since it is correct for the year of my car.
Cheers, John |
JeffBowlsby |
Jun 14 2018, 09:10 PM
914 Wiring Harnesses Group: Members Posts: 8,486 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Well if you want one correct for the yr of your car, you not only need the correct GA code but the SN needs to be within the right rangefor your model year.
Lo-Fi Version | Time is now: 3rd May 2024 - 07:00 AM |
