Fuel Gauge Ground |
Fuel Gauge Ground |
David in VA |
Jun 15 2018, 06:49 AM
Newbie Group: Members Posts: 9 Joined: 5-June 17 From: Richmond, VA Member No.: 21,153 Region Association: MidAtlantic Region |
Does anybody know where the fuel gauge grounds? I tested my sender and it seems to be working fine, grounds are connected to the back of the gauge and it reads empty with the key off and full with the ignition on. Never goes down though, I'd like the check the ground connection but don't know where it is.
Thanks David |
toolguy |
Jun 15 2018, 07:50 AM
Senior Member Group: Members Posts: 1,267 Joined: 2-April 11 From: San Diego / El Cajon Member No.: 12,889 Region Association: Southern California |
all the gauges share a common BRN ground loop wire. . that the gauge will read full
should indicate the ground is good. When did the gauge work correctly last? what happened since? sounds more like a sender rheostat issue. |
Lo-Fi Version | Time is now: 12th May 2024 - 10:54 PM |
