CSP Bellcrank Linkage, Need correct part number for 914 |
1adam12 |
Jun 15 2018, 01:10 PM
Member Group: Members Posts: 209 Joined: 25-May 17 From: Chino Hills, CA Member No.: 21,132 Region Association: Southern California |
Hey guys! I called Cip1 today and the rep wasn't sure if I could use the CSP bellcrank linkage on my 914 due to the fact that the Type 4 model states fits 911 fan shroud. I found an older thread here with some links but I want to make sure I'm ordering the correct item.
I have a 4 cyl model with Dellorto 40's. I'm thinking it would be the Type 4 version for IDF but just want to double check here. |
mobymutt |
Jun 15 2018, 01:48 PM
Senior Member Group: Members Posts: 550 Joined: 16-December 13 From: Kingston, Ontario, Canada Member No.: 16,770 Region Association: Canada |
I didn't install a return spring -- the ones on the carbs do the trick. Actually requires a lot more accelerator pedal force now (vs my old cross-bar linkage), due to the new linkage geometry.
1adam12 |
Jun 15 2018, 02:03 PM
I didn't install a return spring -- the ones on the carbs do the trick. Actually requires a lot more accelerator pedal force now (vs my old cross-bar linkage), due to the new linkage geometry. NICE! Going to take advantage of the Father's Day Special. 20% off and Free Shipping... Why Yes I Will. |
Lo-Fi Version | Time is now: 19th May 2024 - 02:08 AM |
