Race engine piston to cyclinder clearance, How much is too little? |
Driver174 |
Jun 17 2018, 11:07 AM
Member Group: Members Posts: 106 Joined: 2-February 17 From: Nevada Member No.: 20,806 Region Association: None |
914-4 2.0L approx. 10.5:1, JE forged 2618 Aluminum pistons, Web 163/86b cam
JE clearance guidlines say to set clearance to .0035" along with a note "some applications may require more clearance". I had cyclinders bored 0.75 mm oversize with piston clearance of 0.0035", but am having second thoughts; maybe should of increased clearance to .0045. Engine will see road racing conditions, so will get run hard for 20-30 minutes or more during each race. Should I increase the piston clearance? I'm assembling the engine now so it's not too late to address. Thanks, Jim |
Driver174 |
Jun 19 2018, 12:19 PM
Any thoughts before I assemble this engine? I checked the clearance of each piston/bore, and am going to put largest of .0038” in # 3 position.
Thanks again, |
ChrisFoley |
Jun 20 2018, 06:39 AM
I am Tangerine Racing Group: Members Posts: 7,909 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
Probably not too many engine builders looking in this forum on a regular basis, Jim.
I bet you would get some opinions if you posted the same topic in the Garage. |
wndsrfr |
Jun 20 2018, 07:57 AM
Senior Member Group: Members Posts: 1,428 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region |
Len Hoffman...(HAM inc.)...advised me when I put JE's in my 2316....I advise you to PM him before you increase that clearance.....as I recall he said not to exceed .0025", so you're maybe past that already....
Krieger |
Jun 20 2018, 11:23 PM
Advanced Member Group: Members Posts: 4,702 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
FWIW, I just finished building a 911 six. I used Wayne Dempsey's engine build book a he recommends 1.5mm clearance for intake and 2.0mm for exhaust.
Lo-Fi Version | Time is now: 25th April 2024 - 02:27 PM |
