PMOs and altitude changes, Questions and experience |
914forme |
Jun 17 2018, 04:56 PM
I am working on getting the 2.7L redone for dad's 914-6 project. Plan is to drive it to Okteenerfest, and take dad for a beautiful run in the Georgia Mountains. I am not as good as I would like to be with carbs, more of an EFI guy. For some reason PMOs carbs are calling my name.
My one question comes into elevation changes. I really don't want to build the car and then hate the drive if they can't transition well with elevation changes. Any one with experience and know they won't frustrate running up the mountain roads? Are the PMO carbs worth the price of admission? |
Mike Bellis |
Jun 17 2018, 05:50 PM
I don't know PMO. But no carbs adjust to elevation. It's a factor of oxygen density. Higher elevation is less oxygen. Less oxygen requires less fuel. Less fuel requires a jet change. Carbs should be tuned for your primary elevation. I'm sure some work better than others but if you travel through a bunch of elevations changes, EFI is a better choice.
Lo-Fi Version | Time is now: 27th May 2024 - 07:26 PM |
