Running Rich, Fuel Injection to Carburators |
BENBRO02 |
Jun 18 2018, 10:45 AM
Member Group: Members Posts: 481 Joined: 6-March 15 From: Nokesville, Virginia Member No.: 18,493 Region Association: MidAtlantic Region |
I finally got my 914 on the road but switched to carbs to save money. The car runs rich. I have heard that the stock cam is not the perfect profile for carbs and also that the car needs to be run slightly rich to keep the engine temperature down. I have never adjusted a carb before and was wondering if I should try to lean the mixture myself or if this is better left to an expert. I recall that if an engine runs lean bad things can happen to pistons and valves.
JeffBowlsby |
Jun 18 2018, 06:12 PM
914 Wiring Harnesses Group: Members Posts: 8,510 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
And once you pay a mechanic to fiddle with the carbs...the FI will be less expensive overall. Sell the carbs, put the FI back on. You can do this yourself...its not that hard.
Lo-Fi Version | Time is now: 17th May 2024 - 07:22 PM |
