Front Sway bar, Front sway bar |
simonjb |
Jun 18 2018, 03:03 PM
KiwiMan Group: Members Posts: 563 Joined: 18-October 16 From: Stamford, Connecticut Member No.: 20,505 Region Association: North East States |
Probably a stupid question, but do all of the front sway bar products require welding to the chassis? My car did not come with sway bars.
Thanks |
Literati914 |
Jun 29 2022, 04:20 PM
Senior Member Group: Members Posts: 1,461 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
Honestly, I think this is just a case of 'there's more than one way to skin a cat'... and probably most don't even realize it could be done as the factory apparently did it. It is a clean method, but for me (at least on my current project) I like having the heavy/thick bracket on the inside - 'cause that way it sandwiches the thin sheetmetal (from the body) between inside bracket and outside mount. I've actually even wondered how necessary the bracket being welded was, when putting the bracket inside the tank cavity... I'm mean the metal sandwich is under torque from 3 nut/bolts/lock washers each side.
brant |
Jun 29 2022, 04:25 PM
914 Wizard Group: Members Posts: 11,624 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
Honestly, I think this is just a case of 'there's more than one way to skin a cat'... and probably most don't even realize it could be done as the factory apparently did it. It is a clean method, but for me (at least on my current project) I like having the heavy/thick bracket on the inside - 'cause that way it sandwiches the thin sheetmetal (from the body) between inside bracket and outside mount. I've actually even wondered how necessary the bracket being welded was, when putting the bracket inside the tank cavity... I'm mean the metal sandwich is under torque from 3 nut/bolts/lock washers each side. . It’s necessary on the track I say that because I ripped metal out on a car I used to race that didn’t have a sandwiched plate once |
Lo-Fi Version | Time is now: 17th May 2024 - 02:53 PM |
