A Question for Those in the Know, I have an alignment question - UPDATE: Problem Solved |
76-914 |
Jun 19 2018, 06:11 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,483 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
I had my '73 aligned a week before Rt66 and failed to give it a proper road test before hitting the road About 70mph it begins to vibrate a bit and ceases around 80mph. Before having it aligned it drove like a dream but ate the front tires. Living in the sticks I don't have a lot of choices so I'm hoping someone can gleam these "before and after" alignment details and make a recommendation so that I can have it set correctly. TIA, Kent (IMG:style_emoticons/default/beerchug.gif) PS, click on the pic to view it upright.
jcd914 |
Jun 19 2018, 06:28 PM
It is not likely the it is an alignment issue.
There is nothing in the alignment specs that would contribute to a vibration. Vibrations at speeds above about 40 mph are almost always tire and wheel related. I personally have never seen a high speed vibration that was alignment but I try not to say "X never causes Y". Are the wheels stock? I would be looking at the tires and wheels for balance issues or out of round? 73 should be hub centric wheels so they should be centered properly but I would check anyway. Jim |
TravisNeff |
Jun 19 2018, 07:12 PM
Sounds like a wheel balance or bent rim problem. Try putting the rear wheels on the front and see if that makes any difference.
What does look a little odd is the camber difference in the front, it is like they did not adjust that at all. |
Chris914n6 |
Jun 19 2018, 08:30 PM
Jackstands are my life. Group: Members Posts: 3,302 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
Same tires or did you replace the fronts?
If same worn tires then they will behave odd as there will not be a flat contact patch. What's up with the 1* camber difference up front and .5* rear. Laziness? |
914_teener |
Jun 19 2018, 08:32 PM
914 Guru Group: Members Posts: 5,193 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
(IMG:style_emoticons/default/agree.gif) +2
Looks like they just adjusted the front toe. If your fronts were scrubbed then the tires are probably out of balance. I think I run more castor then that but I.d have to check.....been awhile. How come ya didn.t do it yourself Kent? |
76-914 |
Jun 20 2018, 07:48 AM
The tires are new and balanced when installed. The ride was smooth as ice and I had the alignment done so that they did not wear as the old tires had. After the alignment is when the vibration began. The wheels are OEM Fuch's. I guess it is possible that they are NOT balanced properly. The guy at the alignment shop is easy to work with so I guess I can go back and complain but I was hoping to have some direction for him to follow. I was hoping that there were specs that I could provide the alignment shop with. The thing that has me chasing my tail is that Jim Hoyland posted his alignment specs and they vary from mine. Should I present them with his spec's and ask them to duplicate Jim's settings?
Here are Jim's alignment spec's which he posted here 2-3 mo's ago. |
Spoke |
Jun 20 2018, 09:23 AM
Jerry Group: Members Posts: 6,972 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
So with toe out there's no vibration. With toe at zero you've picked up a vibration.
What shape are the wheel bearings, ball joints, and tie rod ends? Any looseness in these items can introduce vibration. With toe out, the stress on bearing, ball joints, and tie rod ends is normally in one direction. With toe at zero, it would seem the items might be stressed in both directions thus any play could result in some wobble in the steering wheel. |
'73-914kid |
Jun 20 2018, 09:39 AM
Senior Member Group: Members Posts: 1,473 Joined: 1-November 08 From: Vista, CA Member No.: 9,714 Region Association: Southern California |
Net 0 toe in the front is a little aggressive for street driving in my opinion.. even on my car I run just a touch of toe-in on the front for freeway stability. The concrete freeway beds in California make's zero toe, or toe out alignments particularly divergent too.
Also, check your wheel bearing's up front. I've had a bearing that lost preload, and the only indicator was a vibration that got slowly worse in the steering wheel. |
Elliot Cannon |
Jun 20 2018, 11:03 AM
Loose tie rods.
76-914 |
Jun 20 2018, 03:06 PM
Net 0 toe in the front is a little aggressive for street driving in my opinion.. even on my car I run just a touch of toe-in on the front for freeway stability. The concrete freeway beds in California make's zero toe, or toe out alignments particularly divergent too. Also, check your wheel bearing's up front. I've had a bearing that lost preload, and the only indicator was a vibration that got slowly worse in the steering wheel. Loose tie rods. I'll check those as well. They have 11000 miles on them. (IMG:style_emoticons/default/beerchug.gif) |
Elliot Cannon |
Jun 20 2018, 03:51 PM
Jack the car up, grip the tire at 12 o:clock and 6 o:clock and try to wiggle it back and forth. There should be NO play in it at all. (Either that, or your car is just CURSED) (IMG:style_emoticons/default/av-943.gif)
914forme |
Jun 20 2018, 06:09 PM
(IMG:style_emoticons/default/headbang.gif) Kent do your own alignment (IMG:style_emoticons/default/headbang.gif) Your smart enough to do the simple math. I do it with strings, and a framing square. A couple of pieces of wood and some grease to make a slip plate. A couple of thick tiles and wax paper will do the same and not make a mess.
Alignment is most likely not the issue. But since they adjusted the tow, make sure all the locking nuts are in place.. etc... Scott made a really nice fixture for home alignment. I will most likely build a set of hub stands when I get the chance. Sherline had a great set they used to sell that would also do corner weights, with bearings to take off the friction from moving the alignment. Very neat setup. (IMG:style_emoticons/default/headbang.gif) Does not look like they are building the system anymore. (IMG:style_emoticons/default/headbang.gif) |
76-914 |
Jun 20 2018, 09:37 PM
(IMG:style_emoticons/default/headbang.gif) Kent do your own alignment (IMG:style_emoticons/default/headbang.gif) Your smart enough to do the simple math. I do it with strings, and a framing square. A couple of pieces of wood and some grease to make a slip plate. A couple of thick tiles and wax paper will do the same and not make a mess. Alignment is most likely not the issue. But since they adjusted the tow, make sure all the locking nuts are in place.. etc... Scott made a really nice fixture for home alignment. I will most likely build a set of hub stands when I get the chance. Sherline had a great set they used to sell that would also do corner weights, with bearings to take off the friction from moving the alignment. Very neat setup. (IMG:style_emoticons/default/headbang.gif) Does not look like they are building the system anymore. (IMG:style_emoticons/default/headbang.gif) I thought about it but my understanding is that one needs a level floor. My garage floor slopes front to rear and left to right! (IMG:style_emoticons/default/confused24.gif) |
914_teener |
Jun 21 2018, 01:04 AM
(IMG:style_emoticons/default/headbang.gif) Kent do your own alignment (IMG:style_emoticons/default/headbang.gif) Your smart enough to do the simple math. I do it with strings, and a framing square. A couple of pieces of wood and some grease to make a slip plate. A couple of thick tiles and wax paper will do the same and not make a mess. Alignment is most likely not the issue. But since they adjusted the tow, make sure all the locking nuts are in place.. etc... Scott made a really nice fixture for home alignment. I will most likely build a set of hub stands when I get the chance. Sherline had a great set they used to sell that would also do corner weights, with bearings to take off the friction from moving the alignment. Very neat setup. (IMG:style_emoticons/default/headbang.gif) Does not look like they are building the system anymore. (IMG:style_emoticons/default/headbang.gif) I thought about it but my understanding is that one needs a level floor. My garage floor slopes front to rear and left to right! (IMG:style_emoticons/default/confused24.gif) Mine is pretty level. I've done it before and my floor is free. Up to you. And yes....despite what other people say....I think you might be smart enough. Susan is a mean cook. |
Bartlett 914 |
Jun 21 2018, 05:52 AM
Advanced Member Group: Members Posts: 2,214 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
Net 0 toe in the front is a little aggressive for street driving in my opinion.. even on my car I run just a touch of toe-in on the front for freeway stability. The concrete freeway beds in California make's zero toe, or toe out alignments particularly divergent too. Also, check your wheel bearing's up front. I've had a bearing that lost preload, and the only indicator was a vibration that got slowly worse in the steering wheel. (IMG:style_emoticons/default/agree.gif) I was fighting similar problems. The front wheel bearing was simply a little too loose. |
majkos1 |
Jun 21 2018, 08:28 AM
Member Group: Members Posts: 212 Joined: 11-August 17 From: Mile High 914 Member No.: 21,338 Region Association: Rocky Mountains |
I had similar issues,
Replaced a worn bearing, Vibration at 60 went away. |
76-914 |
Jun 21 2018, 11:27 AM
(IMG:style_emoticons/default/headbang.gif) Kent do your own alignment (IMG:style_emoticons/default/headbang.gif) Your smart enough to do the simple math. I do it with strings, and a framing square. A couple of pieces of wood and some grease to make a slip plate. A couple of thick tiles and wax paper will do the same and not make a mess. Alignment is most likely not the issue. But since they adjusted the tow, make sure all the locking nuts are in place.. etc... Scott made a really nice fixture for home alignment. I will most likely build a set of hub stands when I get the chance. Sherline had a great set they used to sell that would also do corner weights, with bearings to take off the friction from moving the alignment. Very neat setup. (IMG:style_emoticons/default/headbang.gif) Does not look like they are building the system anymore. (IMG:style_emoticons/default/headbang.gif) I thought about it but my understanding is that one needs a level floor. My garage floor slopes front to rear and left to right! (IMG:style_emoticons/default/confused24.gif) Mine is pretty level. I've done it before and my floor is free. Up to you. And yes....despite what other people say....I think you might be smart enough. Susan is a mean cook. Thanks Rob, I may take you up on that. I need to sort out the bearing and tie rod possibilities first. If nothing changes I will take it in for a tire balance to be sure I didn't chunk a weight before hooking up with you. TIA, Kent |
John |
Jun 21 2018, 11:37 AM
I'm guessing that your front tires are worn slightly funny from the toe-out you had before.
Can't believe they didn't adjust camber to even it up side to side or fix your rear alignment. I like to have even toe in the rear to give a decent thrust line. Have a look at your front tires and look for wear or feathering. If you can, put your rear wheels on the front and see if you still have some vibration in the steering or if it goes away. The tires/rims could simply need balancing. Good luck with it. It is easy enough to do a decent alignment with string, jack stands, a ruler and time, but I prefer my alignment machine since I have one. |
76-914 |
Jun 21 2018, 11:52 AM
I'm guessing that your front tires are worn slightly funny from the toe-out you had before. Can't believe they didn't adjust camber to even it up side to side or fix your rear alignment. I like to have even toe in the rear to give a decent thrust line. Have a look at your front tires and look for wear or feathering. If you can, put your rear wheels on the front and see if you still have some vibration in the steering or if it goes away. The tires/rims could simply need balancing. Good luck with it. It is easy enough to do a decent alignment with string, jack stands, a ruler and time, but I prefer my alignment machine since I have one. Tires are new; or were. Have about 1600 miles on them now. And they didn't vibrate before the alignment. (IMG:style_emoticons/default/confused24.gif) |
John |
Jun 21 2018, 11:57 AM
I'm guessing that your front tires are worn slightly funny from the toe-out you had before. Can't believe they didn't adjust camber to even it up side to side or fix your rear alignment. I like to have even toe in the rear to give a decent thrust line. Have a look at your front tires and look for wear or feathering. If you can, put your rear wheels on the front and see if you still have some vibration in the steering or if it goes away. The tires/rims could simply need balancing. Good luck with it. It is easy enough to do a decent alignment with string, jack stands, a ruler and time, but I prefer my alignment machine since I have one. Tires are new; or were. Have about 1600 miles on them now. And they didn't vibrate before the alignment. (IMG:style_emoticons/default/confused24.gif) I'd definitely suggest that you swap tires front to rear and if the problem persists, you will find something worn out in the front. Wheel bearing(s), tie-rod(s), ball joint(s) that the previous alignment was masking. |
Lo-Fi Version | Time is now: 18th April 2024 - 07:16 PM |
