A Question for Those in the Know, I have an alignment question - UPDATE: Problem Solved |
76-914 |
Jun 19 2018, 06:11 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,495 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
I had my '73 aligned a week before Rt66 and failed to give it a proper road test before hitting the road About 70mph it begins to vibrate a bit and ceases around 80mph. Before having it aligned it drove like a dream but ate the front tires. Living in the sticks I don't have a lot of choices so I'm hoping someone can gleam these "before and after" alignment details and make a recommendation so that I can have it set correctly. TIA, Kent (IMG:style_emoticons/default/beerchug.gif) PS, click on the pic to view it upright.
jcd914 |
Jun 19 2018, 06:28 PM
Advanced Member Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
It is not likely the it is an alignment issue.
There is nothing in the alignment specs that would contribute to a vibration. Vibrations at speeds above about 40 mph are almost always tire and wheel related. I personally have never seen a high speed vibration that was alignment but I try not to say "X never causes Y". Are the wheels stock? I would be looking at the tires and wheels for balance issues or out of round? 73 should be hub centric wheels so they should be centered properly but I would check anyway. Jim |
Lo-Fi Version | Time is now: 9th May 2024 - 03:26 PM |
