A Question for Those in the Know, I have an alignment question - UPDATE: Problem Solved |
76-914 |
Jun 19 2018, 06:11 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,496 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
I had my '73 aligned a week before Rt66 and failed to give it a proper road test before hitting the road About 70mph it begins to vibrate a bit and ceases around 80mph. Before having it aligned it drove like a dream but ate the front tires. Living in the sticks I don't have a lot of choices so I'm hoping someone can gleam these "before and after" alignment details and make a recommendation so that I can have it set correctly. TIA, Kent (IMG:style_emoticons/default/beerchug.gif) PS, click on the pic to view it upright.
Spoke |
Jun 20 2018, 09:23 AM
Jerry Group: Members Posts: 6,978 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
So with toe out there's no vibration. With toe at zero you've picked up a vibration.
What shape are the wheel bearings, ball joints, and tie rod ends? Any looseness in these items can introduce vibration. With toe out, the stress on bearing, ball joints, and tie rod ends is normally in one direction. With toe at zero, it would seem the items might be stressed in both directions thus any play could result in some wobble in the steering wheel. |
Lo-Fi Version | Time is now: 10th May 2024 - 09:49 AM |
