A Question for Those in the Know, I have an alignment question - UPDATE: Problem Solved |
76-914 |
Jun 19 2018, 06:11 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,495 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
I had my '73 aligned a week before Rt66 and failed to give it a proper road test before hitting the road About 70mph it begins to vibrate a bit and ceases around 80mph. Before having it aligned it drove like a dream but ate the front tires. Living in the sticks I don't have a lot of choices so I'm hoping someone can gleam these "before and after" alignment details and make a recommendation so that I can have it set correctly. TIA, Kent (IMG:style_emoticons/default/beerchug.gif) PS, click on the pic to view it upright.
76-914 |
Jun 20 2018, 03:06 PM
Net 0 toe in the front is a little aggressive for street driving in my opinion.. even on my car I run just a touch of toe-in on the front for freeway stability. The concrete freeway beds in California make's zero toe, or toe out alignments particularly divergent too. Also, check your wheel bearing's up front. I've had a bearing that lost preload, and the only indicator was a vibration that got slowly worse in the steering wheel. Loose tie rods. I'll check those as well. They have 11000 miles on them. (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 9th May 2024 - 06:54 PM |
