A Question for Those in the Know, I have an alignment question - UPDATE: Problem Solved |
76-914 |
Jun 19 2018, 06:11 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,495 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
I had my '73 aligned a week before Rt66 and failed to give it a proper road test before hitting the road About 70mph it begins to vibrate a bit and ceases around 80mph. Before having it aligned it drove like a dream but ate the front tires. Living in the sticks I don't have a lot of choices so I'm hoping someone can gleam these "before and after" alignment details and make a recommendation so that I can have it set correctly. TIA, Kent (IMG:style_emoticons/default/beerchug.gif) PS, click on the pic to view it upright.
914forme |
Jun 20 2018, 06:09 PM
(IMG:style_emoticons/default/headbang.gif) Kent do your own alignment (IMG:style_emoticons/default/headbang.gif) Your smart enough to do the simple math. I do it with strings, and a framing square. A couple of pieces of wood and some grease to make a slip plate. A couple of thick tiles and wax paper will do the same and not make a mess.
Alignment is most likely not the issue. But since they adjusted the tow, make sure all the locking nuts are in place.. etc... Scott made a really nice fixture for home alignment. I will most likely build a set of hub stands when I get the chance. Sherline had a great set they used to sell that would also do corner weights, with bearings to take off the friction from moving the alignment. Very neat setup. (IMG:style_emoticons/default/headbang.gif) Does not look like they are building the system anymore. (IMG:style_emoticons/default/headbang.gif) |
76-914 |
Jun 20 2018, 09:37 PM
(IMG:style_emoticons/default/headbang.gif) Kent do your own alignment (IMG:style_emoticons/default/headbang.gif) Your smart enough to do the simple math. I do it with strings, and a framing square. A couple of pieces of wood and some grease to make a slip plate. A couple of thick tiles and wax paper will do the same and not make a mess. Alignment is most likely not the issue. But since they adjusted the tow, make sure all the locking nuts are in place.. etc... Scott made a really nice fixture for home alignment. I will most likely build a set of hub stands when I get the chance. Sherline had a great set they used to sell that would also do corner weights, with bearings to take off the friction from moving the alignment. Very neat setup. (IMG:style_emoticons/default/headbang.gif) Does not look like they are building the system anymore. (IMG:style_emoticons/default/headbang.gif) I thought about it but my understanding is that one needs a level floor. My garage floor slopes front to rear and left to right! (IMG:style_emoticons/default/confused24.gif) |
914_teener |
Jun 21 2018, 01:04 AM
914 Guru Group: Members Posts: 5,197 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
(IMG:style_emoticons/default/headbang.gif) Kent do your own alignment (IMG:style_emoticons/default/headbang.gif) Your smart enough to do the simple math. I do it with strings, and a framing square. A couple of pieces of wood and some grease to make a slip plate. A couple of thick tiles and wax paper will do the same and not make a mess. Alignment is most likely not the issue. But since they adjusted the tow, make sure all the locking nuts are in place.. etc... Scott made a really nice fixture for home alignment. I will most likely build a set of hub stands when I get the chance. Sherline had a great set they used to sell that would also do corner weights, with bearings to take off the friction from moving the alignment. Very neat setup. (IMG:style_emoticons/default/headbang.gif) Does not look like they are building the system anymore. (IMG:style_emoticons/default/headbang.gif) I thought about it but my understanding is that one needs a level floor. My garage floor slopes front to rear and left to right! (IMG:style_emoticons/default/confused24.gif) Mine is pretty level. I've done it before and my floor is free. Up to you. And yes....despite what other people say....I think you might be smart enough. Susan is a mean cook. |
Lo-Fi Version | Time is now: 9th May 2024 - 02:21 PM |
