A Question for Those in the Know, I have an alignment question - UPDATE: Problem Solved |
76-914 |
Jun 19 2018, 06:11 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,496 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
I had my '73 aligned a week before Rt66 and failed to give it a proper road test before hitting the road About 70mph it begins to vibrate a bit and ceases around 80mph. Before having it aligned it drove like a dream but ate the front tires. Living in the sticks I don't have a lot of choices so I'm hoping someone can gleam these "before and after" alignment details and make a recommendation so that I can have it set correctly. TIA, Kent (IMG:style_emoticons/default/beerchug.gif) PS, click on the pic to view it upright.
taylspin46 |
Jun 22 2018, 06:29 PM
Newbie Group: Members Posts: 24 Joined: 25-January 13 From: Apopka Member No.: 15,422 Region Association: South East States |
I had my '73 aligned a week before Rt66 and failed to give it a proper road test before hitting the road About 70mph it begins to vibrate a bit and ceases around 80mph. Before having it aligned it drove like a dream but ate the front tires. Living in the sticks I don't have a lot of choices so I'm hoping someone can gleam these "before and after" alignment details and make a recommendation so that I can have it set correctly. TIA, Kent (IMG:style_emoticons/default/beerchug.gif) PS, click on the pic to view it upright. So basically the only thing adjusted was front toe. Return the car for an actual 4 wheel alignment if that’s what you paid for.. Basic adjustments: Front: Camber minus 0.3 degrees Castor. 6 to 6.5 degrees Toe. Plus 0.3 degrees (total) Rear: Camber. minus 0.5 to 0.75 degrees (both sides equal) Toe. plus 0.2- 0.25 degrees (total). Large differences in this adjustment cause squirreliness at speed and cornering. |
76-914 |
Jun 23 2018, 09:34 AM
I had my '73 aligned a week before Rt66 and failed to give it a proper road test before hitting the road About 70mph it begins to vibrate a bit and ceases around 80mph. Before having it aligned it drove like a dream but ate the front tires. Living in the sticks I don't have a lot of choices so I'm hoping someone can gleam these "before and after" alignment details and make a recommendation so that I can have it set correctly. TIA, Kent (IMG:style_emoticons/default/beerchug.gif) PS, click on the pic to view it upright. So basically the only thing adjusted was front toe. Return the car for an actual 4 wheel alignment if that’s what you paid for.. Basic adjustments: Front: Camber minus 0.3 degrees Castor. 6 to 6.5 degrees Toe. Plus 0.3 degrees (total) Rear: Camber. minus 0.5 to 0.75 degrees (both sides equal) Toe. plus 0.2- 0.25 degrees (total). Large differences in this adjustment cause squirreliness at speed and cornering. Perfect. TYVM. (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 10th May 2024 - 10:01 AM |
