Cutting front of rear of trunk to make room for distributor, Chevy V8 Conversion |
DickSteinkamp |
Jun 20 2018, 05:35 PM
Senior Member Group: Members Posts: 500 Joined: 27-February 17 From: Bellingham, WA Member No.: 20,876 Region Association: None |
I'm currently running a Mallory dual point distributor, mechanical advance only, with a crab cap in my SBC powered 914. Renegade kit. With this set up, the dizzy fits neatly under the front of the rear trunk overhang with no cutting required. I can even R & R the dizzy if I temporarily lower the engine an inch or so.
I'm not crazy about the lack of vacuum advance, however. Any dizzy with vacuum advance (that I have seen or tried) will require I cut a notch out of the front of the rear trunk. If I do that, I'd like to fabricate a little removable "dog house" to cover the cut out to seal up the rear trunk again. The problem seems to be that if the dog house is tall enough to clear a generic points type Chevy dizzy (for example), it may be too tall to stow the roof panel. I'm sure this has been done many times before. What's the solution? Thanks. |
mgp4591 |
Jun 20 2018, 10:35 PM
914 Guru Group: Members Posts: 5,366 Joined: 1-August 12 From: Salt Lake City Ut Member No.: 14,748 Region Association: Intermountain Region |
I'm currently running a Mallory dual point distributor, mechanical advance only, with a crab cap in my SBC powered 914. Renegade kit. With this set up, the dizzy fits neatly under the front of the rear trunk overhang with no cutting required. I can even R & R the dizzy if I temporarily lower the engine an inch or so. I'm not crazy about the lack of vacuum advance, however. Any dizzy with vacuum advance (that I have seen or tried) will require I cut a notch out of the front of the rear trunk. If I do that, I'd like to fabricate a little removable "dog house" to cover the cut out to seal up the rear trunk again. The problem seems to be that if the dog house is tall enough to clear a generic points type Chevy dizzy (for example), it may be too tall to stow the roof panel. I'm sure this has been done many times before. What's the solution? Thanks. Have you tried a GM HEI? It's got a bunch of voltage, more than the dual point without the hassle. I don't know if it's any shorter though. (IMG:style_emoticons/default/idea.gif) |
DickSteinkamp |
Jun 21 2018, 08:56 AM
Have you tried a GM HEI? It's got a bunch of voltage, more than the dual point without the hassle. I don't know if it's any shorter though. (IMG:style_emoticons/default/idea.gif) Love the HEI, but the OE ones are actually taller than an OE points type dizzy. Is there an aftermarket one that is shorter? Maybe with a remote coil? |
76-914 |
Jun 21 2018, 11:19 AM
DickSteinkamp |
Jun 21 2018, 12:17 PM
Thanks! Great pictures. That's what I had envisioned. Even a stock points type dizzy. It still "looks" to me like the roof panel will not fit in the trunk with this set up due to the height of the "dog house". I hope I'm wrong. If not, can the dog house be made any shorter and still clear the dizzy? |
Chris914n6 |
Jun 21 2018, 02:23 PM
Jackstands are my life. Group: Members Posts: 3,304 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
Might have to take the pad off the front. But, hey, it's lighter.
76-914 |
Jun 21 2018, 05:45 PM
Thanks! Great pictures. That's what I had envisioned. Even a stock points type dizzy. It still "looks" to me like the roof panel will not fit in the trunk with this set up due to the height of the "dog house". I hope I'm wrong. If not, can the dog house be made any shorter and still clear the dizzy? It is close but the lid still fits in there! (IMG:style_emoticons/default/beerchug.gif) |
DickSteinkamp |
Jun 21 2018, 05:47 PM
Great! Thanks for your help. |
jim_hoyland |
Jun 21 2018, 05:49 PM
Get that VIN ? Group: Members Posts: 9,262 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Which tach adapter are you using ?
DickSteinkamp |
Jun 21 2018, 05:56 PM
Which tach adapter are you using ? TachAdapt (IMG:http://www.914world.com/bbs2/uploads_offsite/ashlocktech.com-20876-1529625406.1.png) |
jim_hoyland |
Jun 21 2018, 07:22 PM
Which tach adapter are you using ? TachAdapt (IMG:http://www.914world.com/bbs2/uploads_offsite/ashlocktech.com-20876-1529625406.1.png) I have a question regarding the 6 tiny switches inside the Adapter. Which two did you select and did you remove the “jumper” ? Reason I ask: I helping to set one up on a V8 conversion. So far I tried 1 and 6 ; but no tach readings. |
mgp4591 |
Jun 22 2018, 01:32 AM
Have you tried a GM HEI? It's got a bunch of voltage, more than the dual point without the hassle. I don't know if it's any shorter though. (IMG:style_emoticons/default/idea.gif) Love the HEI, but the OE ones are actually taller than an OE points type dizzy. Is there an aftermarket one that is shorter? Maybe with a remote coil? That I'm not sure of... maybe one of the models for another year but I don't know. I looked up these and they might work... HEI Distributor (3112) by BTP®. With Low Profile Cap. Works with 12 volt system. Distributors are high quality, made to last performance parts. (ebay) Technical - Lowering an HEI distributor cap | The H.A.M.B. - The ... https://www.jalopyjournal.com |
76-914 |
Jun 22 2018, 07:40 AM
Pull the jumper, Jim. (IMG:style_emoticons/default/beerchug.gif)
DickSteinkamp |
Jun 22 2018, 08:47 AM
I have a question regarding the 6 tiny switches inside the Adapter. Which two did you select and did you remove the “jumper” ? Reason I ask: I helping to set one up on a V8 conversion. So far I tried 1 and 6 ; but no tach readings. Here are the complete instructions. Instructions |
76-914 |
Jun 22 2018, 02:26 PM
Jim, the guy is local and will answer your emails with 24hr's if you have questions. (IMG:style_emoticons/default/beerchug.gif)
jim_hoyland |
Jun 22 2018, 04:25 PM
I have a question regarding the 6 tiny switches inside the Adapter. Which two did you select and did you remove the “jumper” ? Reason I ask: I helping to set one up on a V8 conversion. So far I tried 1 and 6 ; but no tach readings. Here are the complete instructions. Instructions That helps, I think it needs 1 and 6 ON I had 1 and 5 ON Can’t do any testing until thr fuel tank is reinstalled |
76-914 |
Jun 22 2018, 05:01 PM
I have a question regarding the 6 tiny switches inside the Adapter. Which two did you select and did you remove the “jumper” ? Reason I ask: I helping to set one up on a V8 conversion. So far I tried 1 and 6 ; but no tach readings. Here are the complete instructions. Instructions That helps, I think it needs 1 and 6 ON I had 1 and 5 ON Can’t do any testing until thr fuel tank is reinstalled Yep, toggle 1 & 6 also remove the jumper. The signal is too weak if that jumper is left in place. (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 25th April 2024 - 05:21 PM |
