WTB; Battery Cut Off Switch/Handle |
crsedge |
Jun 21 2018, 05:15 AM
Newbie Group: Members Posts: 32 Joined: 25-March 12 From: Australia Member No.: 14,304 Region Association: None |
Hi All,
I am looking for this variety of battery cut off switch. Firstly, has anyone seen one before as I have consulted Dr Google and can't find a picture of one through various searches and secondly does anyone have one for sale (IMG:style_emoticons/default/smile.gif) Cheers Craig Attached thumbnail(s) |
SixerJ |
Jun 21 2018, 05:34 AM
Member Group: Members Posts: 448 Joined: 24-June 13 From: UK Member No.: 16,042 Region Association: England |
Think you will find that’s a fire pull handle. would then be routed to pull / rotate the actual cut off switch usually between the seats
Not an exact match but Lifeline handles are very similar Fairly sure Armandos pbase site has pictorial examples of that type of set up Jon |
crsedge |
Jun 21 2018, 06:08 AM
Think you will find that’s a fire pull handle. would then be routed to pull / rotate the actual cut off switch usually between the seats Not an exact match but Lifeline handles are very similar Fairly sure Armandos pbase site has pictorial examples of that type of set up Jon Thanks Jon, Think you are correct, thanks. I can only find plastic ones though, the one in the picture appears to be metal? Cheers Craig |
eric9144 |
Jun 21 2018, 08:33 AM
Advanced Member Group: Members Posts: 2,732 Joined: 30-March 11 From: San Diego, CA Member No.: 12,876 Region Association: Southern California |
Your picture is gone, but I'm guessing you're looking for this?
https://smile.amazon.com/Bosch-341001001-Ba...y+cutoff+handle |
crsedge |
Jun 21 2018, 03:09 PM
Your picture is gone, but I'm guessing you're looking for this? https://smile.amazon.com/Bosch-341001001-Ba...y+cutoff+handle Thanks Eric. Don't know what happen to the photo I included, have reposted. The link you have provided looks like the switch closest to the windscreen in the photo which I also didn't have (IMG:style_emoticons/default/smile.gif) Am keen to find an older version of the Lifeline Handle in metal if possible? Cheers Craig |
forrestkhaag |
Jun 21 2018, 08:22 PM
I recently bought the period-correct 914-6 GT (metal) battery cutoff switch from Eric Shea at PMB. His near perfect GT clone sports the same cutoff switch.
(IMG:style_emoticons/default/beerchug.gif) |
crsedge |
Jun 23 2018, 04:30 AM
I recently bought the period-correct 914-6 GT (metal) battery cutoff switch from Eric Shea at PMB. His near perfect GT clone sports the same cutoff switch. (IMG:style_emoticons/default/beerchug.gif) Do you mean the black battery cut off switch in the photo or the ref T-Handle? I can see the black variety listed on the PMB site but not the red one? Cheers Craig |
Lo-Fi Version | Time is now: 18th April 2024 - 04:38 PM |
