seal shrinkage what glue |
JFG |
Jun 21 2018, 05:22 AM
Senior Member Group: Members Posts: 686 Joined: 7-April 16 From: Wales Member No.: 19,869 Region Association: None |
One of my door window seals seems to have shrunk a bit. I have some of the old seal in the leftovers box so i'm looking at sticking a small piece onto it to extend it back to fit properly.
What is the best adhesive to use? |
IronHillRestorations |
Jun 21 2018, 05:30 AM
I. I. R. C. Group: Members Posts: 6,716 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
Contact cement, put the adhesive on both parts, let it dry a bit, carefully align the parts before they touch and put them together
Mikey914 |
Jun 21 2018, 06:19 AM
The rubber man Group: Members Posts: 12,659 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
The shrinkahe you speak of is a result of pulling the seal through the track. Rubber has memory, and even though you think you've compressed it back, you never really get it all. So over time with expansion and contraction, it returned to it's unstressed size. This is why Ill tell anyone that instalks tbe targa to window seal to locate where the end shoukd be and install the outside edge 1st pushing the inside edge in to secure it.
With that being said, you can use super glue for a good bond. |
Lo-Fi Version | Time is now: 10th May 2024 - 06:02 AM |
