New photos of my engine |
PanelBilly |
Jun 22 2018, 08:38 PM
914 Guru Group: Members Posts: 5,797 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
mb911 |
Jun 22 2018, 08:41 PM
914 Guru Group: Members Posts: 6,811 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
Ugh.. Not good..
Are the cylinders rotated 180 degrees? Pictures make it look like the larger portion of the fins are pointing upwards?? |
PanelBilly |
Jun 22 2018, 10:05 PM
mb911 |
Jun 23 2018, 05:16 AM
Ugh.. Not good.. Are the cylinders rotated 180 degrees? Pictures make it look like the larger portion of the fins are pointing upwards?? ?? Looks like that to me too. So the bigger fins go down? Typically yes.. Exhaust is the hotter side of the piston and cylinder. Fyi pistons are right for sure though. |
Luke M |
Jun 23 2018, 07:59 AM
Senior Member Group: Members Posts: 1,369 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States |
Looks like some JE pistons. Big pockets in pistons face up and long fins on cylinders go down. Looks like a 3.0 to me. Do the cylinders have the head gaskets or are you using the 3.2 cylinders w/o gaskets? Why was it torn down?
I added some pics of my brothers 83 3.0 with JE pistons and Mahle cylinders. He has the 3.0 cylinders with the head gaskets. You can kinda see that the cylinders fins are almost the same (flat) across the top. On the bottom you can see the fins get taller as they get closer the the heads. Have your engine guy look into that before he closes it up. Attached image(s) |
Lo-Fi Version | Time is now: 25th April 2024 - 05:09 PM |
