Side shift rear pin locating hole, What to use to drill a new hole? |
DaveO90s4 |
Jun 23 2018, 01:45 AM
Member Group: Members Posts: 149 Joined: 26-April 16 From: Australia Member No.: 19,935 Region Association: None |
Hi all,
For my Corvair conversion I've had to mount to engine & trans assembly about 20mm further rearward. So I have had to lengthen the side shift shifter rod by that same amount (at the rear end of the rod). So now I need to drill a new grub screw locating pin hole in that extended shift rod. I assume I need to drill a tapered hole so to match the taper angle on the locating pin. Is that correct? And if so what special drill bit do I need to buy? Thanks all DaveO PS 2.8L Corvair engine in the 914 is a really nice setup - and a relatively cheap 6 conversion option too. |
theer |
Jun 23 2018, 05:07 AM
Senior Member Group: Members Posts: 676 Joined: 31-July 15 From: Dover, MA Member No.: 19,014 Region Association: North East States |
There is such a thing called tapered end mill, that requires a milling machine. Might be easier to cut off the factory end put the extension in the middle. Or cut the factory end off a second linkage and attach that.
Lo-Fi Version | Time is now: 18th May 2024 - 04:25 PM |
