Side shift rear pin locating hole, What to use to drill a new hole? |
DaveO90s4 |
Jun 23 2018, 01:45 AM
Member Group: Members Posts: 149 Joined: 26-April 16 From: Australia Member No.: 19,935 Region Association: None |
Hi all,
For my Corvair conversion I've had to mount to engine & trans assembly about 20mm further rearward. So I have had to lengthen the side shift shifter rod by that same amount (at the rear end of the rod). So now I need to drill a new grub screw locating pin hole in that extended shift rod. I assume I need to drill a tapered hole so to match the taper angle on the locating pin. Is that correct? And if so what special drill bit do I need to buy? Thanks all DaveO PS 2.8L Corvair engine in the 914 is a really nice setup - and a relatively cheap 6 conversion option too. |
DaveO90s4 |
Jun 23 2018, 02:44 PM
Thanks Theer, tapered end mill it is. Not keen on any cutting, want to use existing hole as a linear alignment mark for my new hole: same orientation just 20mm further aft.
Cheers DaveO |
Lo-Fi Version | Time is now: 25th May 2024 - 01:23 PM |
