19mm master cylinder and bigger calipers?, What combo have you upgraded to? |
Mueller |
Jun 23 2018, 12:34 PM
What combo calipers are being used with the 19mm master cylinder besides stock?
Looking to ditch my rear stock calipers since going to drum style parking brakes. I'm open to upgrade front brakes at same time.... 911 parts? 944 turbo parts? Boxster parts? Wilwood parts? I'm open to ideas. |
porschetub |
Jun 23 2018, 03:11 PM
Advanced Member Group: Members Posts: 4,696 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
What combo calipers are being used with the 19mm master cylinder besides stock? Looking to ditch my rear stock calipers since going to drum style parking brakes. I'm open to upgrade front brakes at same time.... 911 parts? 944 turbo parts? Boxster parts? Wilwood parts? I'm open to ideas. The PO had fitted Brembo 4 pots (944S2) front and rear,pretty easily done without adaptor brackets and works great with 19mm ATE master cylinder,shame the hand brake set up was crap,I have re-engineered 80% of it so far. |
Jun 23 2018, 03:13 PM
Resident German Group: Admin Posts: 41,602 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Boxster all around, best "upgrade" i ever made to the car (besides the engine of course) ...
(IMG:style_emoticons/default/driving.gif) |
Mueller |
Jun 23 2018, 03:14 PM
Boxster all around, best "upgrade" i ever made to the car (besides the engine of course) ... (IMG:style_emoticons/default/driving.gif) And you are running 15" wheels correct? Got a link to your brake install? |
Jun 23 2018, 03:17 PM
Boxster all around, best "upgrade" i ever made to the car (besides the engine of course) ... (IMG:style_emoticons/default/driving.gif) And you are running 15" wheels correct? Got a link to your brake install? 15" wheels, yes. Lemmy search and see if i posted the install ... (IMG:style_emoticons/default/type.gif) |
Jun 23 2018, 03:19 PM
Lemmy search and see if i posted the install ... Found it: http://www.914world.com/bbs2/index.php?showtopic=170890 (IMG:style_emoticons/default/smile.gif) |
worn |
Jun 23 2018, 03:54 PM
can't remember Group: Members Posts: 3,144 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
What combo calipers are being used with the 19mm master cylinder besides stock? Looking to ditch my rear stock calipers since going to drum style parking brakes. I'm open to upgrade front brakes at same time.... 911 parts? 944 turbo parts? Boxster parts? Wilwood parts? I'm open to ideas. I run a 19 mm master, and aluminum 911 s calipers up front and 911sc rear brakes aft. The alu calipers are pricey tho. Still I like the setup very much with the five lug setup. |
Mueller |
Jun 23 2018, 10:37 PM
Lemmy search and see if i posted the install ... Found it: http://www.914world.com/bbs2/index.php?showtopic=170890 (IMG:style_emoticons/default/smile.gif) Thanks, lots of good info and links in that thread. I'm off work for a few more weeks, I need to swing by your place with my BBS rims and do a test fit front and rear. |
jcd914 |
Jun 24 2018, 12:00 AM
What combo calipers are being used with the 19mm master cylinder besides stock? Looking to ditch my rear stock calipers since going to drum style parking brakes. I'm open to upgrade front brakes at same time.... 911 parts? 944 turbo parts? Boxster parts? Wilwood parts? I'm open to ideas. I run a 19 mm master, and aluminum 911 s calipers up front and 911sc rear brakes aft. The alu calipers are pricey tho. Still I like the setup very much with the five lug setup. I ran 911T struts and brakes on the front of my old 914 with 19mm master cylinder. I don't know what master cylinder my current 914 has but I have a pair of Alfa Romeo Brembo aluminum front calipers that have 3 inch caliper bolt spacing so they bolt on early 911 strut. They would bolt on to 914 struts but the calipers are made for the thicker vented rotors. I have only run 914 rear calipers but have read that 914 front calipers bolt on the rear. Jim |
Mueller |
Jun 24 2018, 10:34 AM
Boxster all around, best "upgrade" i ever made to the car (besides the engine of course) ... (IMG:style_emoticons/default/driving.gif) Found a set of 4 Boxster calipers for $350 shipped in our classifieds, they are on the way to me right now! Not sure how I am going to handle the front end, I have 3" spacing struts and not too sure I like how aAron Cox had to modify the brake mount on his struts. |
914forme |
Jun 24 2018, 10:43 AM
I run a 19 mm master, and aluminum 911 s calipers up front and 911sc rear brakes aft. The alu calipers are pricey tho. Still I like the setup very much with the five lug setup. I ran 911T struts and brakes on the front of my old 914 with 19mm master cylinder. I don't know what master cylinder my current 914 has but I have a pair of Alfa Romeo Brembo aluminum front calipers that have 3 inch caliper bolt spacing so they bolt on early 911 strut. They would bolt on to 914 struts but the calipers are made for the thicker vented rotors. I have only run 914 rear calipers but have read that 914 front calipers bolt on the rear. I run the same setup on a 19mm. I run 914-6 rear calipers, 911 M calipers should work. The nice thing of the Brembo, it is a 911S caliper, with a 3" bolt spacing and huge pads. Alfa GTV and GTA I think. You can get pads to match front and rear from I forgot if you need to know, I'll go to the shop and look at the stacks of boxes. (IMG:style_emoticons/default/dry.gif) also Ran 911 Carrera front and rear from a 1987 911 donor on a 19mm worked great, but a bit heavy. The Boxster S and the like come out to needing a 21mm master or 23mm, I can't remember now, (IMG:style_emoticons/default/confused24.gif) did that math like 5 years ago, have the parts, not done yet. (IMG:style_emoticons/default/headbang.gif) |
wndsrfr |
Jun 24 2018, 05:51 PM
Senior Member Group: Members Posts: 1,428 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region |
What combo calipers are being used with the 19mm master cylinder besides stock? Looking to ditch my rear stock calipers since going to drum style parking brakes. I'm open to upgrade front brakes at same time.... 911 parts? 944 turbo parts? Boxster parts? Wilwood parts? I'm open to ideas. Do a search on "Wilwood" under my screen name "wndsrfr" & page down to post #20 to see my input regarding Wilwoods...they are relatively inexpensive, rotors are only about $40 each and way lighter than anything else to reduce unsprung weight on the front... |
Lo-Fi Version | Time is now: 20th April 2024 - 07:50 AM |
