Transmission problems, Grinds when shifting at low rpm |
tsvo |
Jun 23 2018, 06:58 PM
Member Group: Members Posts: 123 Joined: 30-January 16 From: Chicago Member No.: 19,616 Region Association: Upper MidWest |
I have a 1973 with side shirt trans. It started grinding shifting into first gear and also reverse. It seems to be at low rpm only, hence 1st and reverse. I do not know that for certain, I stopped driving it. Clutch seems fine. Any suggestions?
TheCabinetmaker |
Jun 23 2018, 07:18 PM
I drive my car everyday Group: Members Posts: 8,300 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Have you adjusted the clutch? Checked the shift bushings? Transmission full of gear lube?
Dave_Darling |
Jun 24 2018, 01:19 PM
914 Idiot Group: Members Posts: 14,981 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Clutch seems fine? Cool. But is it in fact fine?
That's a classic sign of a clutch that is not releasing all the way. --DD |
Lo-Fi Version | Time is now: 4th May 2024 - 09:27 AM |
