Overthinking frunk reinforcement install, Advice on painting prep |
bbrock |
Jun 23 2018, 07:39 PM
Alright, I know I'm overthinking this but it's driving me crazy. I need to reinstall my front trunk reinforcement on my rustoration build soon and originally planned to spray the backs of the reinforcement brackets and the area under the headlight buckets with 2K primer while everything was open and accessible. Then I would spray color in there as best I can when I do the rest of the chassis which won't be for several months. The primer needs to be top-coated within two weeks without having to scuff sand, but once the pieces are welded in, sanding in there won't be possible. So what do you all think is the best way to proceed for best long term rust protection and being able to get color in that recess so it looks factory correct? Maybe just spray the backs of the reinforcement brackets now and save the rest for later even though it is a PITA to get paint in there? (IMG:style_emoticons/default/confused24.gif)
bbrock |
Jun 24 2018, 08:27 AM
Thanks guys. I wasn't planning to buy color and clear until I got closer to ready to paint (with luck, this fall) so hadn't considered the option of spraying color now. But will think about it.
There is an older thread about spraying this difficult area with a good pic illustrating my delima. The only area that can't be seen is the surface on the back side of the two-holed brace. The rest of the area is hard to see, but you'll be able to tell if there's color in the right light or if you crane your neck enough. Since I'm hoping to get as close to a "factory fresh" look as my limited skills will allow, it would bug me. As long as I knew I could get good coverage in there after parts are welded in, I wouldn't worry. Anyone have a recommendation on a reasonably placed wand that might help? (IMG:http://www.914world.com/bbs2/uploads/post-3574-1471209911.jpg) |
Lo-Fi Version | Time is now: 14th May 2024 - 09:53 PM |
