Overthinking frunk reinforcement install, Advice on painting prep |
bbrock |
Jun 23 2018, 07:39 PM
Alright, I know I'm overthinking this but it's driving me crazy. I need to reinstall my front trunk reinforcement on my rustoration build soon and originally planned to spray the backs of the reinforcement brackets and the area under the headlight buckets with 2K primer while everything was open and accessible. Then I would spray color in there as best I can when I do the rest of the chassis which won't be for several months. The primer needs to be top-coated within two weeks without having to scuff sand, but once the pieces are welded in, sanding in there won't be possible. So what do you all think is the best way to proceed for best long term rust protection and being able to get color in that recess so it looks factory correct? Maybe just spray the backs of the reinforcement brackets now and save the rest for later even though it is a PITA to get paint in there? (IMG:style_emoticons/default/confused24.gif)
914forme |
Jun 24 2018, 09:15 AM
Times a wastin', get wrenchin'! Group: Members Posts: 3,896 Joined: 24-July 04 From: Dayton, Ohio Member No.: 2,388 Region Association: None |
Go with a single stage on the inside pieces, no reason to clear the inside you can get single and base clears in matching colors. Singles make it so much easier to work with on interior sections.
Also you will get burn off and the paint can burn around your weld so keep the heat down, you will want to take your time, weld in the open air, and still wear a respirator. Have a good leather glove you can use to crush any flare ups that might come up. |
Lo-Fi Version | Time is now: 15th May 2024 - 04:52 PM |
