Rear sway bar orientation |
troth |
Jun 24 2018, 11:40 AM
Member Group: Members Posts: 151 Joined: 17-August 16 From: CT/WA Member No.: 20,305 Region Association: None |
914Sixer |
Jun 24 2018, 12:01 PM
914 Guru Group: Members Posts: 8,862 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Correct with bar facing the rear and drop links to the shock tower.
troth |
Jun 24 2018, 12:09 PM
Correct with bar facing the rear and drop links to the shock tower. (IMG:style_emoticons/default/beerchug.gif) |
914Toy |
Jun 24 2018, 12:11 PM
Senior Member Group: Members Posts: 715 Joined: 12-November 17 From: Laguna beach Member No.: 21,596 Region Association: Southern California |
Jun 24 2018, 12:12 PM
914 Idiot Group: Members Posts: 14,980 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
It's pretty obvious when you get it under the car. The long part of the bar goes up against the trunk floor, then the arms of the bar go toward where the back of the trailing arms are.
The bends in the middle of the bar go up toward the trunk floor in order to make sure there is clearance for the transmission. --DD |
David Billo |
Jun 24 2018, 12:17 PM
Member Group: Members Posts: 64 Joined: 23-November 17 From: Plainfield, Ontario Member No.: 21,625 Region Association: Canada |
OP pic is correct...the first bend in the arms, after coming out of the straightaway, curves upwards. (had to go out to the garage and look at mine to confirm)
rgalla9146 |
Jun 24 2018, 12:26 PM
Advanced Member Group: Members Posts: 4,544 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
The picture is correct with the droop of the side arm down toward the floor and the link balls forward. Put it in upside down ? the curved arms will hit the floor crossmember over bad bumps. Also if you find it upside down you'll have to remove the muffler to fix it. I recently corrected it on a friends car. |
Larmo63 |
Jun 24 2018, 12:42 PM
It looks upside down to me too.
I thought that the arms curved down. It really only works one way in the car. |
Lo-Fi Version | Time is now: 17th April 2024 - 07:46 PM |
