Valve collision problem |
thomasotten |
Jun 30 2018, 08:03 PM
Senior Member Group: Members Posts: 1,544 Joined: 16-November 03 From: San Antonio, Texas Member No.: 1,349 |
I am having a bit of a problem with my latest 2 liter build. Basically, valves are colliding with pistons after warm up during break in. A valve got stuck and the pushrod actually fell off the rocker.
The heads were redon by RIMCO. After the problem happened, I pulled the heads, and there was clear indication of valve collision, and I had a valve stuck open. The head with a problem was sent back to RIMCO. Reinstalled. What happened this time is the engine start up from cold, runs fine. But then I can hear the taping of collision again. The taping is accompanied by a chirping sound that sounds like something is dragging. I think it must be the valves dragging and closing too slow. I have a deck height of .065. This is essentially a stock build, stock camshaft, etc. Any ideas? Is this perhaps a valve stem lubrication issue? |
thomasotten |
Jul 1 2018, 07:49 AM
Stuck intake valve
Attached thumbnail(s) |
Mark Henry |
Jul 1 2018, 08:35 AM
Mark Henry |
Jul 1 2018, 09:30 AM
Stuck intake valve I often see this when a seat is falling out. Take the head off and look at that valve, if it is a seat it will be sitting cocked in it's bore. If it sits back down take the valve off and either knock the seat around a bit or heat it to 375-400 in an oven (chambers facing down) and see if the seat falls out. |
Lo-Fi Version | Time is now: 12th May 2024 - 09:39 PM |
