Valve collision problem |
thomasotten |
Jun 30 2018, 08:03 PM
Senior Member Group: Members Posts: 1,544 Joined: 16-November 03 From: San Antonio, Texas Member No.: 1,349 |
I am having a bit of a problem with my latest 2 liter build. Basically, valves are colliding with pistons after warm up during break in. A valve got stuck and the pushrod actually fell off the rocker.
The heads were redon by RIMCO. After the problem happened, I pulled the heads, and there was clear indication of valve collision, and I had a valve stuck open. The head with a problem was sent back to RIMCO. Reinstalled. What happened this time is the engine start up from cold, runs fine. But then I can hear the taping of collision again. The taping is accompanied by a chirping sound that sounds like something is dragging. I think it must be the valves dragging and closing too slow. I have a deck height of .065. This is essentially a stock build, stock camshaft, etc. Any ideas? Is this perhaps a valve stem lubrication issue? |
thelogo |
Jun 30 2018, 09:58 PM
Senior Member Group: Retired Members Posts: 1,510 Joined: 6-April 10 Member No.: 11,572 Region Association: None |
I am having a bit of a problem with my latest 2 liter build. Basically, valves are colliding with pistons after warm up during break in. A valve got stuck and the pushrod actually fell off the rocker. The heads were redon by RIMCO. After the problem happened, I pulled the heads, and there was clear indication of valve collision, and I had a valve stuck open. The head with a problem was sent back to RIMCO. Reinstalled. What happened this time is the engine start up from cold, runs fine. But then I can hear the taping of collision again. The taping is accompanied by a chirping sound that sounds like something is dragging. I think it must be the valves dragging and closing too slow. I have a deck height of .065. This is essentially a stock build, stock camshaft, etc. Any ideas? Is this perhaps a valve stem lubrication issue? I thought if the valve gets stuck or struck the engine instantly destroy s itself ? |
Mueller |
Jul 1 2018, 10:50 AM
I thought if the valve gets stuck or struck the engine instantly destroy s itself ? The valves move in the same direction of the pistons, they are not canted or at an angle relative to the piston top so if you get lucky they just get pushed back straight if they contact a piston. |
Lo-Fi Version | Time is now: 13th May 2024 - 09:20 AM |
