Valve collision problem |
thomasotten |
Jun 30 2018, 08:03 PM
Senior Member Group: Members Posts: 1,544 Joined: 16-November 03 From: San Antonio, Texas Member No.: 1,349 |
I am having a bit of a problem with my latest 2 liter build. Basically, valves are colliding with pistons after warm up during break in. A valve got stuck and the pushrod actually fell off the rocker.
The heads were redon by RIMCO. After the problem happened, I pulled the heads, and there was clear indication of valve collision, and I had a valve stuck open. The head with a problem was sent back to RIMCO. Reinstalled. What happened this time is the engine start up from cold, runs fine. But then I can hear the taping of collision again. The taping is accompanied by a chirping sound that sounds like something is dragging. I think it must be the valves dragging and closing too slow. I have a deck height of .065. This is essentially a stock build, stock camshaft, etc. Any ideas? Is this perhaps a valve stem lubrication issue? |
Mark Henry |
Jul 1 2018, 02:36 PM
Maybe you should get your injectors checked/cleaned and flow tested.
thomasotten |
Jul 1 2018, 04:26 PM
Maybe you should get your injectors checked/cleaned and flow tested. Will do. The engine didn't run for very long, so I am not sure if I have a lean condition. I understand that valve guide lubrication occurs from the rocker side oil. Someone on the phone at the machinist was telling me it is also lubed by gasoline spray. I can't see how that would work. In any case, does someone have the specs so I can measure for myself if the valve guides were reemed properly? |
Lo-Fi Version | Time is now: 13th May 2024 - 07:39 AM |
