Valve collision problem |
thomasotten |
Jun 30 2018, 08:03 PM
Senior Member Group: Members Posts: 1,544 Joined: 16-November 03 From: San Antonio, Texas Member No.: 1,349 |
I am having a bit of a problem with my latest 2 liter build. Basically, valves are colliding with pistons after warm up during break in. A valve got stuck and the pushrod actually fell off the rocker.
The heads were redon by RIMCO. After the problem happened, I pulled the heads, and there was clear indication of valve collision, and I had a valve stuck open. The head with a problem was sent back to RIMCO. Reinstalled. What happened this time is the engine start up from cold, runs fine. But then I can hear the taping of collision again. The taping is accompanied by a chirping sound that sounds like something is dragging. I think it must be the valves dragging and closing too slow. I have a deck height of .065. This is essentially a stock build, stock camshaft, etc. Any ideas? Is this perhaps a valve stem lubrication issue? |
thomasotten |
Jul 1 2018, 05:01 PM
So, after sitting on the workbench for a few hours, I noticed that the
valve sprung back closed on its own. So I got the spring compressor and removed thr spring. Gave the stem a little tap with a rubber hammer: Valve was tight! It came out with a few taps. I immediately noticed the fine Brass shavings again. Here I point to one... Attached thumbnail(s) |
Lo-Fi Version | Time is now: 12th May 2024 - 04:32 PM |
