How can I tell if Driver or Passenger seat, I have Extra Seat |
xperu |
Jul 2 2018, 05:18 PM
TEXAS Group: Members Posts: 597 Joined: 13-June 06 From: League City Texas Member No.: 6,213 Region Association: None |
I have an extra seat with no rails. I would like to know if it's a passenger or drivers seat. I think they tilt in a particular way, can I set it on a level surface and tell the orientation without the slider attached? Thanks Mike Kelly
Jul 2 2018, 05:40 PM
914-6 GT in waiting Group: Members Posts: 19,238 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Yes. Level surface. The higher side of the headrest goes in the center of the car. So if the higher side (from the back) is on the right, it’s a driver side. Also, many driver side seats have a noticible indentation for the e-brake.
xperu |
Jul 2 2018, 08:07 PM
Yes. Level surface. The higher side of the headrest goes in the center of the car. So if the higher side (from the back) is on the right, it’s a driver side. Also, many driver side seats have a noticible indentation for the e-brake. Thanks Mark, l’ll give it a look. Mike |
milwlandrover |
Jul 29 2018, 03:32 PM
Member Group: Members Posts: 149 Joined: 22-June 12 From: Greendale Wisconsin Member No.: 14,592 Region Association: Upper MidWest |
The steering wheel is in front of the drivers seat?
Jul 29 2018, 03:37 PM
Rand |
Jul 29 2018, 03:43 PM
Also look for the indentation on the left side of the driver's seat for the ebrake clearance.
Rob-O |
Jul 29 2018, 10:16 PM
Senior Member Group: Members Posts: 1,251 Joined: 5-December 03 From: Mansfield, TX Member No.: 1,419 Region Association: Southwest Region |
Yes. Level surface. The higher side of the headrest goes in the center of the car. So if the higher side (from the back) is on the right, it’s a driver side. Also, many driver side seats have a noticible indentation for the e-brake. Pretty sure you have that backwards. From The back of the car looking through the rear window towards the front of the car, the drivers seat head test will be larger on the LEFT side of the seat. The arc of the rear window of the car is such that the lower parts of the arc are at the left and right edges of the rear window. The highest part in the center of the rear window. To compensate for this the back of the headrest is thicker towards the left or right of the driver or passenger seat, respectively. |
Jul 30 2018, 05:39 AM
Yes. Level surface. The higher side of the headrest goes in the center of the car. So if the higher side (from the back) is on the right, it’s a driver side. Also, many driver side seats have a noticible indentation for the e-brake. Pretty sure you have that backwards. From The back of the car looking through the rear window towards the front of the car, the drivers seat head test will be larger on the LEFT side of the seat. The arc of the rear window of the car is such that the lower parts of the arc are at the left and right edges of the rear window. The highest part in the center of the rear window. To compensate for this the back of the headrest is thicker towards the left or right of the driver or passenger seat, respectively. If you put both seats on level ground, the seats will be as I described. The rear window doesn’t change how you place the seats. |
Lo-Fi Version | Time is now: 25th April 2024 - 12:12 AM |
