914 Diesel build.... |
PatrickB |
Jul 4 2018, 04:30 AM
Member Group: Members Posts: 249 Joined: 26-March 17 From: sw ontario Member No.: 20,960 Region Association: Canada |
Here goes nothin....
Been planning this for a while, but it was supposed to be a winter project. Wasn't quite ready yet. KEP adaptor parts have been sitting here. Timeline moved up because of a failure. Had a chirp that turned into a BAD miss, valve seat issue on one cylinder. Had a fresh 1.9 AAZ diesel sitting in my storage trailer that had never been fired. (honed, rings, bearings, injection pump reseal). "new" engine was destined for my daily beater . Same engine in the beater is getting a little tired, I've put at least 350,000 km on it and the compression is getting down. Still runs okay though. Swapped the "new" engine into the beater. 16 year old son is learning... |
914forme |
Jul 5 2018, 08:49 AM
Times a wastin', get wrenchin'! Group: Members Posts: 3,896 Joined: 24-July 04 From: Dayton, Ohio Member No.: 2,388 Region Association: None |
I used to Auto-x an A3 Jetta, loved that little car.
Fooling the actuator is pretty easy, most people just used an aquarium air valve, old school. Small restrictor will also work. As far as the 901 goes you will be fine. The Evil Dr. will be a great resource I would look for an H or HA 5th, and play around with the rest of the gearing. His Evil one can tell you what gears can be sourced cheaply and should work with the diesel. I used to launch my 914-4 in 2nd gear at the auto-x so with the diesel you should be fine in second. That removes the weakest part of the trans. Cooling should be easy as this engine only really produces heat under load. So a small rad should be easy. Just look at the size of the stock Rabbit Rad and calculate the cooling area. Then find something that fits. You might be able to use a couple well placed Heater cores from a large truck, and get enough airflow to keep the front trunk like Brant's oil coolers on his race car. I love cheap builds, and mine start that way and spin out of control with while I am in their itis. |
PatrickB |
Jul 5 2018, 10:43 AM
I used to Auto-x an A3 Jetta, loved that little car. Fooling the actuator is pretty easy, most people just used an aquarium air valve, old school. Small restrictor will also work. As far as the 901 goes you will be fine. The Evil Dr. will be a great resource I would look for an H or HA 5th, and play around with the rest of the gearing. His Evil one can tell you what gears can be sourced cheaply and should work with the diesel. I used to launch my 914-4 in 2nd gear at the auto-x so with the diesel you should be fine in second. That removes the weakest part of the trans. Cooling should be easy as this engine only really produces heat under load. So a small rad should be easy. Just look at the size of the stock Rabbit Rad and calculate the cooling area. Then find something that fits. You might be able to use a couple well placed Heater cores from a large truck, and get enough airflow to keep the front trunk like Brant's oil coolers on his race car. I love cheap builds, and mine start that way and spin out of control with while I am in their itis. What |I did to fool the waste gate on the K14 was pull out one of the banjo bolts and drill a small hole to bleed a little boost off the signal line. Neater than a valve and incognito. Just keep going a little bigger hole until I get where I want to be. Apparently this engine is good for about 30 pounds without head studs. No point going that high without an intercooler though.20 pounds is lots. The K14 actually is adjustable but I was afraid of breaking the bolt off. T3 is not adjustable. Might pull the same trick on it. As for cooling, plan is to get the engine sitting in place, then figure out what room is left. Then make a trip to a wrecking yard with a tape measure... I'd like to use the rad out of a mark 3 golf (2 fans) I have sitting here but I don't think it will fit... unless I can mount it across the front of the engine bay a little low and on an angle, air flow directed from under the car. Not counting on that. I've been running diesels for a long time and you're right, they don't make a lot of heat unless they're working hard. My kid was showing me pictures of Honda rads that might work. VW Fox should work but probably hard to find. |
Lo-Fi Version | Time is now: 16th May 2024 - 01:07 AM |
