914 Diesel build.... |
PatrickB |
Jul 4 2018, 04:30 AM
Member Group: Members Posts: 249 Joined: 26-March 17 From: sw ontario Member No.: 20,960 Region Association: Canada |
Here goes nothin....
Been planning this for a while, but it was supposed to be a winter project. Wasn't quite ready yet. KEP adaptor parts have been sitting here. Timeline moved up because of a failure. Had a chirp that turned into a BAD miss, valve seat issue on one cylinder. Had a fresh 1.9 AAZ diesel sitting in my storage trailer that had never been fired. (honed, rings, bearings, injection pump reseal). "new" engine was destined for my daily beater . Same engine in the beater is getting a little tired, I've put at least 350,000 km on it and the compression is getting down. Still runs okay though. Swapped the "new" engine into the beater. 16 year old son is learning... |
Chris H. |
Jul 17 2018, 12:21 PM
Senior Member Group: Members Posts: 4,030 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest |
Yes the Vanagon diesel oil pan allows you to turn the engine 50 degrees in order to get it under the Vanagon deck lid. Many people use them to install other VW engines into the Vanagon such as the 1.8t or a newer TDI engine. It's a direct bolt up for many inline VW engines. No reason you couldn't use it for a 914 diesel.
You can buy a used one, or maybe contact these guys and see if they will sell just the pan. Foreign Auto Supply It's real fancy compared to the stock pan (IMG:style_emoticons/default/biggrin.gif) . Scroll down and you can see how the setup installs into a Vanagon. It's kind of alarming how much it's tilted but since the oil pan compensates it runs just the same as any other engine. |
Lo-Fi Version | Time is now: 15th May 2024 - 12:41 PM |
