914 Diesel build.... |
PatrickB |
Jul 4 2018, 04:30 AM
Member Group: Members Posts: 249 Joined: 26-March 17 From: sw ontario Member No.: 20,960 Region Association: Canada |
Here goes nothin....
Been planning this for a while, but it was supposed to be a winter project. Wasn't quite ready yet. KEP adaptor parts have been sitting here. Timeline moved up because of a failure. Had a chirp that turned into a BAD miss, valve seat issue on one cylinder. Had a fresh 1.9 AAZ diesel sitting in my storage trailer that had never been fired. (honed, rings, bearings, injection pump reseal). "new" engine was destined for my daily beater . Same engine in the beater is getting a little tired, I've put at least 350,000 km on it and the compression is getting down. Still runs okay though. Swapped the "new" engine into the beater. 16 year old son is learning... |
Chris914n6 |
Aug 8 2018, 03:25 PM
Jackstands are my life. Group: Members Posts: 3,320 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
You need a drivers side engine mount. No doubt about it.
You can hard mount the crossbar to the engine and use 911 engine sport mounts at the body. I'll see if I have a clear pic of my setup. Can't see it behind the exhaust but the tube is vertical with a 3" gusset. Tube is 1.5" thick wall and plates are iirc 3/16". It's 20-30 lbs beefy or at least it feels like it. Bolts to the factory engine mounts. |
Lo-Fi Version | Time is now: 16th May 2024 - 02:57 AM |
