914 Diesel build.... |
PatrickB |
Jul 4 2018, 04:30 AM
Member Group: Members Posts: 249 Joined: 26-March 17 From: sw ontario Member No.: 20,960 Region Association: Canada |
Here goes nothin....
Been planning this for a while, but it was supposed to be a winter project. Wasn't quite ready yet. KEP adaptor parts have been sitting here. Timeline moved up because of a failure. Had a chirp that turned into a BAD miss, valve seat issue on one cylinder. Had a fresh 1.9 AAZ diesel sitting in my storage trailer that had never been fired. (honed, rings, bearings, injection pump reseal). "new" engine was destined for my daily beater . Same engine in the beater is getting a little tired, I've put at least 350,000 km on it and the compression is getting down. Still runs okay though. Swapped the "new" engine into the beater. 16 year old son is learning... |
Chris914n6 |
Aug 8 2018, 03:25 PM
Jackstands are my life. Group: Members Posts: 3,318 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
You need a drivers side engine mount. No doubt about it.
You can hard mount the crossbar to the engine and use 911 engine sport mounts at the body. I'll see if I have a clear pic of my setup. Can't see it behind the exhaust but the tube is vertical with a 3" gusset. Tube is 1.5" thick wall and plates are iirc 3/16". It's 20-30 lbs beefy or at least it feels like it. Bolts to the factory engine mounts. |
PatrickB |
Aug 9 2018, 05:22 AM
You need a drivers side engine mount. No doubt about it. You can hard mount the crossbar to the engine and use 911 engine sport mounts at the body. I'll see if I have a clear pic of my setup. Thanks, looking forward to seeing it. I think we'll use what we've got short term with another mount on the other side, but may build something else in the long run. soft mounts at the bar to the body makes a lot of sense to me. |
stownsen914 |
Aug 9 2018, 07:29 AM
Agreed with reinforcing your crossbar where the notch is. The first version of my fabricated mount/crossbar for a 911 engine in a /4 chassis broke in the middle due to flexing. Fixed by triangulating in my case.
Cool project, by the way! |
Lo-Fi Version | Time is now: 15th May 2024 - 12:53 PM |
