914 Diesel build.... |
PatrickB |
Jul 4 2018, 04:30 AM
Member Group: Members Posts: 249 Joined: 26-March 17 From: sw ontario Member No.: 20,960 Region Association: Canada |
Here goes nothin....
Been planning this for a while, but it was supposed to be a winter project. Wasn't quite ready yet. KEP adaptor parts have been sitting here. Timeline moved up because of a failure. Had a chirp that turned into a BAD miss, valve seat issue on one cylinder. Had a fresh 1.9 AAZ diesel sitting in my storage trailer that had never been fired. (honed, rings, bearings, injection pump reseal). "new" engine was destined for my daily beater . Same engine in the beater is getting a little tired, I've put at least 350,000 km on it and the compression is getting down. Still runs okay though. Swapped the "new" engine into the beater. 16 year old son is learning... |
Dave_Darling |
Jul 4 2018, 02:03 PM
914 Idiot Group: Members Posts: 14,985 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
I'm wondering about the gearbox... The gearing may be low for a diesel, and I'm wondering how the 901-based box will hold up to diesel torque...
--DD |
porschetub |
Jul 19 2018, 01:36 AM
Advanced Member Group: Members Posts: 4,698 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
I'm wondering about the gearbox... The gearing may be low for a diesel, and I'm wondering how the 901-based box will hold up to diesel torque... --DD Yea me too ,even the crappy early model 60 hp diesel Golf motor can eat out an 020 five speed after not that long. |
PatrickB |
Jul 19 2018, 03:30 AM
I'm wondering about the gearbox... The gearing may be low for a diesel, and I'm wondering how the 901-based box will hold up to diesel torque... --DD Yea me too ,even the crappy early model 60 hp diesel Golf motor can eat out an 020 five speed after not that long. Been running this exact engine on an 020 for a lot of years. Put at least 350,000 kms on it. Replaced one gearbox about 15 years ago not long after I got the car. I guess it depends how you use it.... I don't baby it though. The fuel and boost was turned up a lot of years ago, I'm not shy with the throttle, and I occasionally pull a 1000 pound tent trailer with it. I don't think I'll have problems with the 901. I do run synthetic oil in the 020 though... I wonder if that helps? Made it shift smoother. |
porschetub |
Aug 25 2018, 10:30 PM
I'm wondering about the gearbox... The gearing may be low for a diesel, and I'm wondering how the 901-based box will hold up to diesel torque... --DD Yea me too ,even the crappy early model 60 hp diesel Golf motor can eat out an 020 five speed after not that long. Been running this exact engine on an 020 for a lot of years. Put at least 350,000 kms on it. Replaced one gearbox about 15 years ago not long after I got the car. I guess it depends how you use it.... I don't baby it though. The fuel and boost was turned up a lot of years ago, I'm not shy with the throttle, and I occasionally pull a 1000 pound tent trailer with it. I don't think I'll have problems with the 901. I do run synthetic oil in the 020 though... I wonder if that helps? Made it shift smoother. No was joking really this box had been abused,no guestion about it ,was told it was fine by the PO and was pissed of just for the hassle of changing it as I payed little for it,my son drove the car after fitting and said it was shifting ok but made a "strange noise",turned out the crownwheel was on the way to migrating out the bottom of the gearbox,after years of working on Golfs this was the first case of breaking diff rivets I had come across. Good luck with what you are doing,I like it when people think out of the square,will be following your progress (IMG:style_emoticons/default/beerchug.gif) . |
Lo-Fi Version | Time is now: 15th May 2024 - 01:58 PM |
