914 Diesel build.... |
PatrickB |
Jul 4 2018, 04:30 AM
Member Group: Members Posts: 249 Joined: 26-March 17 From: sw ontario Member No.: 20,960 Region Association: Canada |
Here goes nothin....
Been planning this for a while, but it was supposed to be a winter project. Wasn't quite ready yet. KEP adaptor parts have been sitting here. Timeline moved up because of a failure. Had a chirp that turned into a BAD miss, valve seat issue on one cylinder. Had a fresh 1.9 AAZ diesel sitting in my storage trailer that had never been fired. (honed, rings, bearings, injection pump reseal). "new" engine was destined for my daily beater . Same engine in the beater is getting a little tired, I've put at least 350,000 km on it and the compression is getting down. Still runs okay though. Swapped the "new" engine into the beater. 16 year old son is learning... |
Dave_Darling |
Sep 9 2018, 07:42 PM
914 Idiot Group: Members Posts: 14,985 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
For the throttle, perhaps you could take inspiration from the 911 and 914-6, and fabricate a bellcrank linkage? You ought to be able to find a good place for the bellcrank, then a few rods and rod ends, and you can use the stock cable to run that...
--DD |
PatrickB |
Sep 10 2018, 04:45 PM
For the throttle, perhaps you could take inspiration from the 911 and 914-6, and fabricate a bellcrank linkage? You ought to be able to find a good place for the bellcrank, then a few rods and rod ends, and you can use the stock cable to run that... --DD Maybe.... have to do some looking at it. |
Lo-Fi Version | Time is now: 15th May 2024 - 12:16 PM |
