914 Diesel build.... |
PatrickB |
Jul 4 2018, 04:30 AM
Member Group: Members Posts: 249 Joined: 26-March 17 From: sw ontario Member No.: 20,960 Region Association: Canada |
Here goes nothin....
Been planning this for a while, but it was supposed to be a winter project. Wasn't quite ready yet. KEP adaptor parts have been sitting here. Timeline moved up because of a failure. Had a chirp that turned into a BAD miss, valve seat issue on one cylinder. Had a fresh 1.9 AAZ diesel sitting in my storage trailer that had never been fired. (honed, rings, bearings, injection pump reseal). "new" engine was destined for my daily beater . Same engine in the beater is getting a little tired, I've put at least 350,000 km on it and the compression is getting down. Still runs okay though. Swapped the "new" engine into the beater. 16 year old son is learning... |
PatrickB |
Sep 19 2018, 06:40 PM
Got the tach working tonight with the help of an adaptor box from Dakota digital. takes signal from the w terminal on the alternator and converts it to run the 4 cyl VDO gas tach. Adjustable.... I think it's set close. Need to get it back out ont he road to check. Used to show about 2800 at 60 mph so I'm just going to adjust until it matches that. Don't know if 60 on the guage is actually 60... but it will be close enough to suit me.
Didn't think it was working at first... but then I remembered that standard practice in the old jetta used to be to blip the throttle once to make the alternator kick in. Problem solved! Now waiting for a throttle cable. MIGHT have it back out this weekend. |
Lo-Fi Version | Time is now: 15th May 2024 - 02:04 PM |
