Automatic 914? |
Automatic 914? |
AJB |
Jul 4 2018, 06:57 AM
Member Group: Members Posts: 50 Joined: 18-November 07 From: United Kingdom Member No.: 8,350 Region Association: Europe |
Hey everyone,
I haven't been on here for ages - since I had to get rid of my 914 due to financial problems back during the dark days. However, things have moved on and I'm now able to think about getting another one. the problem is that during these last few years I have suffered left knee issues and have real problems if I have to push a clutch pedal up and down repeatedly. So I now tend to drive only Auto trans cars. Whilst it may seem to many to be sacrilege (I have medical reasons so please don't abuse me too much!), I have a question for kind people on here. Are any of you aware if an auto trans swap has been done into a 914? I was thinking a VW type 4 box would bolt right up - but as they were rear engined and not mid it would be spinning the wrong way. Or what about a Boxster box? This might never happen but I'm just wondering if it's been done before - or even possible! I did try and search but couldn't find anything relevant. Thanks in advance! |
mb911 |
Jul 4 2018, 07:11 AM
914 Guru Group: Members Posts: 6,810 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
Hey everyone, I haven't been on here for ages - since I had to get rid of my 914 due to financial problems back during the dark days. However, things have moved on and I'm now able to think about getting another one. the problem is that during these last few years I have suffered left knee issues and have real problems if I have to push a clutch pedal up and down repeatedly. So I now tend to drive only Auto trans cars. Whilst it may seem to many to be sacrilege (I have medical reasons so please don't abuse me too much!), I have a question for kind people on here. Are any of you aware if an auto trans swap has been done into a 914? I was thinking a VW type 4 box would bolt right up - but as they were rear engined and not mid it would be spinning the wrong way. Or what about a Boxster box? This might never happen but I'm just wondering if it's been done before - or even possible! I did try and search but couldn't find anything relevant. Thanks in advance! I will ultimately be working on a setup for my dad like this. Probably a boxster trans or there is a servo activated clutch system sold in India called an auto clutch. That would still work for your needs.. Those kits sell on ebay or you could also reach out to a company that retrofits cars for folks with disabilities.. |
ClayPerrine |
Jul 4 2018, 07:19 AM
Life's been good to me so far..... Group: Admin Posts: 15,410 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Find a sportomatic and put it in the car.
Still get the fun of shifting, but no clutch. |
AJB |
Jul 4 2018, 07:27 AM
Find a sportomatic and put it in the car. Still get the fun of shifting, but no clutch. I wasn't aware Porsche did this, so I've just been reading up (https://www.total911.com/technology-explained-sportomatic-gearbox/). They must be quite a rare beast - and wouldn't they also be rotating the wrong way due to the 911 rear engine set up? Or is this easily overcome? |
GeorgeRud |
Jul 4 2018, 07:31 AM
No issues as it really only entails flipping the ring and pinion gear. Their actually was a Sportomatic available for the 914, but I’ve never seen one and they are in fact very rare. I think Ben’s idea of adapting a Boxster trans (or installing the automatic clutch) may end up being easier. I have similar issues as you and hope to be able to once again drive my cars so I wish you well. I guess getting older is better than the alternative!
bdstone914 |
Jul 4 2018, 07:47 AM
bdstone914 Group: Members Posts: 4,512 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
I saw an auto trans conversion that I think used an Audi trans. It was built for a lady that could not use a clutch pedal. He is in central California. Not sure if he still has the car. It can be done. One challenge is cooling for the trans. Cooling the trans will be an issue. Most automatic transmissions are in water cooled cars allowing use of a liquid to liquid heat exchanger. It will probably be necessary to use an oil to air cooler on a 914 conversion. Cooler would need to be in a good air flow path.
I had a VW type III squareback with an auto trans. They only used a fined torque converter for cooling which was marginally adaquete. Had to rebuild the trans which back then only cost be $26 for the rebuild kit and my labor to install it. I think only three 914 Sportomatics were know to be build and those were 914-6. |
AJB |
Jul 4 2018, 07:49 AM
The sportomatic looks like an interesting option that I wasn't aware of - thank you. And there are some boxes available on ebay, so they're not as rare as I initially imagined they would be. Getting the switch on the gear lever working might be a challenge, but nothing is impossible. Are the semi auto boxes in the Beetle a similar idea?
So are there any other options? Would an auto box from a type 4 VW work if the pinion and ring gear were flipped over? |
ClayPerrine |
Jul 4 2018, 08:09 AM
The vanagon auto transmission should be a bold up. Get the flex plate with it.
The only thing you would need to do is fabricate a rear transmission mount. (IMG:http://www.914world.com/bbs2/uploads_offsite/lh3.googleusercontent.com-1143-1530713376.1.jpg) |
Chris H. |
Jul 4 2018, 08:33 AM
Senior Member Group: Members Posts: 4,028 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest |
I think the automatic 914 had a FWD Audi 5000 trans from the '80's. Similar to the Vanagon but the gearing was better. |
xperu |
Jul 4 2018, 10:17 AM
TEXAS Group: Members Posts: 597 Joined: 13-June 06 From: League City Texas Member No.: 6,213 Region Association: None |
Hey everyone, I haven't been on here for ages - since I had to get rid of my 914 due to financial problems back during the dark days. However, things have moved on and I'm now able to think about getting another one. the problem is that during these last few years I have suffered left knee issues and have real problems if I have to push a clutch pedal up and down repeatedly. So I now tend to drive only Auto trans cars. Whilst it may seem to many to be sacrilege (I have medical reasons so please don't abuse me too much!), I have a question for kind people on here. Are any of you aware if an auto trans swap has been done into a 914? I was thinking a VW type 4 box would bolt right up - but as they were rear engined and not mid it would be spinning the wrong way. Or what about a Boxster box? This might never happen but I'm just wondering if it's been done before - or even possible! I did try and search but couldn't find anything relevant. Thanks in advance! Somewhere in the forum history there is a thread that went into depth about this. You may want to do a search on automatic xmissions. Even had a lot of pictures. Mike Kelly |
JRust |
Jul 4 2018, 10:33 AM
914 Guru Group: Members Posts: 6,305 Joined: 10-January 03 From: Corvallis Oregon Member No.: 129 Region Association: Pacific Northwest |
I know that Audi transmission car. Mark (computers4kids) had bought it. I know he sold since then but car ran great. Obviously it was a bit slower but not ridiculously so. I can't remember how it was mated to the motor though. http://www.914world.com/bbs2/index.php?sho...=101948&hl=
If doing this type of conversion I would sure consider an all subaru drivetrain. Get more power with your motor & have them matched to each other already. So no adapter plated from drivetrain. Just have to build a cradle for them. |
Steve |
Jul 4 2018, 11:13 AM
914 Guru Group: Members Posts: 5,569 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
Not a fan of 4 speed autos. I would love to see a Subi motor and auto trans. I love my subi BRZ with six speed auto.
Jul 4 2018, 02:10 PM
I believe the 914 Sporto had an extra oil pump and tank (or part of the tank). There were no four-cylinder series-built Sporto cars, so there isn't an extant recipe for them.
The Audi box seems to be the easiest and most feasible way to go. The Boxster trans may be doable, but you'll have to work out how to mount the starter. I do know that there has been at least one Boxster trans (manual, though) on a Six. I'd think the computerized controls for the auto would be a lot of added complexity... A complete drive-train swap is an attractive notion, if you're not interested in keeping an ai-cooled motor. Scooby, Audi (we have a couple of 1.8T swaps around here), or similar. --DD |
Rand |
Jul 4 2018, 02:33 PM
The Sporto was a cool thing, and brings the super cool factor to a build if you want unique. But reality, she nods her head in and says a full Suby drivetrain makes way more practical sense.
mgp4591 |
Jul 4 2018, 02:52 PM
914 Guru Group: Members Posts: 5,366 Joined: 1-August 12 From: Salt Lake City Ut Member No.: 14,748 Region Association: Intermountain Region |
Not a fan of 4 speed autos. I would love to see a Subi motor and auto trans. I love my subi BRZ with six speed auto. The Subie auto trans is freakin' HEAVY.... I ended up going with 225# rear springs and adjustable kit from Rebel Racing just to handle it all but I'm thinking about the possibilities of the Audi 6 spd manual because it has the final gearing that I really want. All of the Subaru auto trans weigh a ton but would work well if you decide to go with the whole Subie package. |
AJB |
Jul 4 2018, 02:58 PM
...I'd think the computerized controls for the auto would be a lot of added complexity... Yes - I also think this would be an issue. Whilst I'm sure it isn't impossible, it's an added complication that I could do without! Sounds like an Audi box might be the most likely then - or a Subi drivetrain, but I'm kinda an old school, air cooled kinda guy |
struckn |
Jul 4 2018, 03:02 PM
Senior Member Group: Members Posts: 1,069 Joined: 9-November 11 From: South Central York Pennsyvania Member No.: 13,764 Region Association: MidAtlantic Region |
A problem that I remember hearing about with using a VW Tiptronic Auto was no one could come up with a way to mount the Engine Starter.
914forme |
Jul 4 2018, 03:39 PM
Boxster or Audi ZF 5hp24 and then you'll need the
As for the Sporto yes you need a different oil pump, yes you will need an oil tank, In reality why? Convert to a a system designed for people who have a disability. Been there once and found thesehere. |
Chris914n6 |
Jul 4 2018, 05:00 PM
Jackstands are my life. Group: Members Posts: 3,304 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
Sounds like you have what I called 'clutch knee', from diving a manual to work everyday. Now that I don't do that anymore the knee problem has gone, so I can drive a 914 all weekend with no adverse effects. I also did some muscle strengthening exercises.
A 90s Subaru Impreza/Legacy would give the better result, plus A/C. An engine bay radiator has been done with the little 2.2L. ECU/TCU wiring is quite basic. The Passat/A4 with Autostick would be trick but it gets alot more complicated with the electronics. |
jjs3rd914 |
Jul 5 2018, 07:31 AM
Member Group: Members Posts: 124 Joined: 8-August 04 From: Sarasota, FL Member No.: 2,476 |
Back in the 80's I had a 1972 VW TypeIV wagen which was a great car before it rusted away in the northeast. I rebuild the 1.7 D-Jet engine and the Auto transmission. Car ran great. Tranny was easy to rebuild, but now I would assume parts might be very hard to get.
As others have pointed out, am not sure the ring and pinion could be flipped as it too was rear engine. If it could that could be one solution as it of course bolted to a type 4 engine. Also I wonder if it was the same tranny used in the later Type 2 and vanagons. If so parts might be easier to get. The cars are impossible to find now, but I always wondered if one could put a 914 (901) 5 speed it it as we know the 901 you can flip the ring/pinion. Thought it would be a fun project for a fun daily driver. jjs3rd914 |
Lo-Fi Version | Time is now: 25th April 2024 - 02:22 PM |
