Carb Setup - Opinions Please, Dual or Single |
vin man |
Jul 4 2018, 11:35 AM
Member Group: Members Posts: 178 Joined: 19-February 10 From: Gilbert, Arizona USA Member No.: 11,380 Region Association: Southwest Region |
I have a new motor in my 914 - 2056 based on the 1.8 core. I had dual weber 40 IDF on the original 1.7 when I got the car and I've been trying to get the motor running but one of the webers is bad.
I have a few options. Find a VW expert, have him/her rebuild the webers and get the car running right. Go with new webers keeping the dual carb setup Look for used dellortos and new linkage to keep the dual carb setup. Go to single carb setup. What are the benefits/drawbacks of the single carb? What I can think of: 1- I have to find a new intake setup. 2- Single carb is simpler 3- Less CFM with the single carb so won't be as much power. Would appreciate any input. Thanks. |
Rand |
Jul 4 2018, 11:45 AM
Don't go single carb. The intake runners are too long for that to work efficiently. I think you'll find this unanimous on 914s (or any flat engine that would require long intake runners).
barefoot |
Jul 4 2018, 01:44 PM
Senior Member Group: Members Posts: 1,275 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
I've just been thru a similar carb tuning issue with dual Dell40 DRLA's. One of mine had poor idle air flow balance between barrels and could not get it to run, lots of popping & backfire. Finally bought another DRLA 40 and that as much better balanced, then tuning was fairly easy.
Get yourself another Webber, or have somebody who knows those things rebuild & balance it. |
xperu |
Jul 4 2018, 01:51 PM
TEXAS Group: Members Posts: 597 Joined: 13-June 06 From: League City Texas Member No.: 6,213 Region Association: None |
Duel carbs, also make sure they are not (Made In China). Look at your cam set up to better support your carbs. Mike Kelly
Jul 4 2018, 01:57 PM
Never singles on our cars. Never.
--DD |
vin man |
Jul 4 2018, 03:49 PM
one of the webers is great. the other is wrong. I've had it apart multiple times, soaked overnight in the carb cleaner, blown out every orifice. I can't find anything wrong with it but no fuel is flowing.
I'm game to go with another setup. Dual dellortos would be nice. But the least expensive option would probably be to have a Weber expert fix the one I have. |
cgnj |
Jul 4 2018, 03:57 PM
Senior Member Group: Members Posts: 623 Joined: 6-March 03 From: Medford, NJ Member No.: 403 Region Association: None |
No gas in the carb at all? Check float adjustment and check valve.
bbrock |
Jul 4 2018, 03:59 PM
Many years ago I ran a single carb on a 1.7 liter 914 and also on a bus. Both SUCKED. Never again.
vin man |
Jul 4 2018, 04:11 PM
nditiz1 |
Jul 4 2018, 04:18 PM
Senior Member Group: Members Posts: 1,188 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region |
Check valve is under the top plate. It is operated via the float. What you should do.
Buy an all new set of dual 40 idf from a reputable company. Pick up Bob tomlisons Weber carb book. Buy good linkage CSP or tangerine. Install carbs. Start the tuning process. Can you work with used carbs, sure if you know what new carbs should act like. With new ones you know the shafts are not worn and they haven't been messed with. You can sell the old ones or eventually fix the bad one and keep them. |
michael7810 |
Jul 4 2018, 04:51 PM
Senior Member Group: Members Posts: 1,081 Joined: 6-June 11 From: Scottsdale, AZ Member No.: 13,164 Region Association: Southwest Region |
one of the webers is great. the other is wrong. I've had it apart multiple times, soaked overnight in the carb cleaner, blown out every orifice. I can't find anything wrong with it but no fuel is flowing. I'm game to go with another setup. Dual dellortos would be nice. But the least expensive option would probably be to have a Weber expert fix the one I have. Are the accel pumps squirting? Are you sure the engine is OK? Intake leak, valve adjustment, idle jets clogged. Did you put a snail on each side to check airflow balance? I have a couple books on Webers that you can borrow. PM if interested. I’m in S Scottsdale |
vin man |
Jul 4 2018, 04:55 PM
one of the webers is great. the other is wrong. I've had it apart multiple times, soaked overnight in the carb cleaner, blown out every orifice. I can't find anything wrong with it but no fuel is flowing. I'm game to go with another setup. Dual dellortos would be nice. But the least expensive option would probably be to have a Weber expert fix the one I have. Are the accel pumps squirting? Are you sure the engine is OK? Intake leak, valve adjustment, idle jets clogged. Did you put a snail on each side to check airflow balance? I have a couple books on Webers that you can borrow. PM if interested. I’m in S Scottsdale Accel pumps are squirting. Engine is new. I've got compression on all cylinders Timing is right Snail balanced I may take you up on the weber books. What are the titles? |
worn |
Jul 4 2018, 06:57 PM
can't remember Group: Members Posts: 3,156 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
e? I have a couple books on Webers that you can borrow. PM if interested. I’m in S Scottsdale Don’t see how you can make it work without knowing how it outta work, o... (IMG:style_emoticons/default/agree.gif) |
rhodyguy |
Jul 4 2018, 07:31 PM
Try Blackline Racing in Murray Utah. You provide the engine specs and they set your carbs up accordingly. You're probably going to wind up switching to 32mm venturis. Not exactly cheap but they are good to go out of the box. Plan on a new linkage. Buy a copy of Thomlinson's WEBER manual from CB performance. If you don't currently use one get a rotary self-regulated fuel pump.
vin man |
Jul 4 2018, 07:38 PM
e? I have a couple books on Webers that you can borrow. PM if interested. I’m in S Scottsdale Don’t see how you can make it work without knowing how it outta work, o... (IMG:style_emoticons/default/agree.gif) I'm wondering if I missed something in the rebuild (obviously I missed something). I'd like to fix what I have now to save time and $. However, I'm not going to shortcut this after all the time and $ I've put into the rest of the build. Something is preventing the fuel from flowing. Either the float (which I checked and is working), or an air flow issue. I'm suspecting the latter. Either a passage is plugged or there is an opening causing an air leak. I blew compressed air through all the openings so I'm more inclined to believe I have a missing plug or a crack in the casting someplace. |
rhodyguy |
Jul 4 2018, 07:51 PM
No fuel is being delivered to the carb?
vin man |
Jul 4 2018, 08:40 PM
michael7810 |
Jul 4 2018, 09:41 PM
one of the webers is great. the other is wrong. I've had it apart multiple times, soaked overnight in the carb cleaner, blown out every orifice. I can't find anything wrong with it but no fuel is flowing. I'm game to go with another setup. Dual dellortos would be nice. But the least expensive option would probably be to have a Weber expert fix the one I have. Are the accel pumps squirting? Are you sure the engine is OK? Intake leak, valve adjustment, idle jets clogged. Did you put a snail on each side to check airflow balance? I have a couple books on Webers that you can borrow. PM if interested. I’m in S Scottsdale Accel pumps are squirting. Engine is new. I've got compression on all cylinders Timing is right Snail balanced I may take you up on the weber books. What are the titles? I have Bob Tomlison’s Weber Tech Manual and Haynes Weber Workshop Manual. I also have Mr Bubbleheads Weber Carb Tuning Instructions. LMK, I’m leaving town tomorrow and will be home Sunday. |
Lo-Fi Version | Time is now: 19th May 2024 - 02:54 PM |
