Me thinks me tranny is going south, outputs have lots of play |
Mark Henry |
Jun 13 2005, 05:15 AM
The tranny was making what I thought was bad CV noises....my one (right) output shaft is moving a good 1/2 inch in/out when I pull on it.
Not worried as I have 3 spares, should I replace it now or let it fail...what happens when one fails like this? What has broke? Is it worth fixing...as in is there a quick fix? |
Joe Ricard |
Jun 13 2005, 05:34 AM
In an out is cool (IMG:http://www.914world.com/bbs2/html/emoticons/sheeplove.gif) axles have to change length as the wheel goes up and down.
side to side is the dangerous direction. UNLESS you are talking about the output hub flange coimng out of the trans. then it's your bolt backing out. |
Mark Henry |
Jun 13 2005, 06:20 AM
Yep Is there a bolt under the CV or a circlip? |
Joe Ricard |
Jun 13 2005, 07:58 AM
Big hardened special... Did I say expensive? bolt that holds the output drive flange to the Differential.
Lo-Fi Version | Time is now: 19th May 2024 - 07:07 AM |
