| dan10101 |
Jul 22 2018, 05:43 PM
TORQUE-o-holic ![]() ![]() ![]() Group: Members Posts: 1,140 Joined: 29-April 03 From: Eagle Point, Or Member No.: 626 Region Association: Pacific Northwest |
My new vote is for drug dealer green metal flake. Heavy 1070's disco speed boat metal flake. You will be unique and the only 914 ever painted this color. (IMG:style_emoticons/default/piratenanner.gif) Hell, put some 26" dubs on it too! (IMG:style_emoticons/default/aktion035.gif) Mike, I like you, but I sense that you've gone off on the whole what color will it be discussion. Did you imbibe in some gin and tonics early this afternoon? |
| Andyrew |
Jul 22 2018, 05:48 PM
Spooling.... Please wait ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,381 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California
I vote for Phoenix Red That's like "Soylent Green is PEOPLE!" "Phoenix Red is ORANGE!" said everyone everywhere. It also happens to be the same color as my car. Or well at least what my Vin says it is (it's actually painted Hugger Orange) For some reason dad has something against Orange for his cars and has this affinity towards RED. So Dad, let's see what's been occupying your time and what the 914 is replacing? I know your just about to start working on it. |
| Mike Bellis |
Jul 22 2018, 07:33 PM
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,348 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None
My new vote is for drug dealer green metal flake. Heavy 1070's disco speed boat metal flake. You will be unique and the only 914 ever painted this color. (IMG:style_emoticons/default/piratenanner.gif) Hell, put some 26" dubs on it too! (IMG:style_emoticons/default/aktion035.gif) Mike, I like you, but I sense that you've gone off on the whole what color will it be discussion. Did you imbibe in some gin and tonics early this afternoon? Actually, margaritas... (IMG:style_emoticons/default/first.gif) I get it. You're afraid if you go heavy metallic green you will get profiled as the old man king pin of the cartel. I understand... (IMG:style_emoticons/default/biggrin.gif) |
| dan10101 |
Jul 22 2018, 09:12 PM
My new vote is for drug dealer green metal flake. Heavy 1070's disco speed boat metal flake. You will be unique and the only 914 ever painted this color. (IMG:style_emoticons/default/piratenanner.gif) Hell, put some 26" dubs on it too! (IMG:style_emoticons/default/aktion035.gif) Mike, I like you, but I sense that you've gone off on the whole what color will it be discussion. Did you imbibe in some gin and tonics early this afternoon? Actually, margaritas... (IMG:style_emoticons/default/first.gif) I get it. You're afraid if you go heavy metallic green you will get profiled as the old man king pin of the cartel. I understand... (IMG:style_emoticons/default/biggrin.gif) I'm probably the only person in the Rogue valley that isn't using his 4 acres growing weed. Well, i grow weeds, but not Weed. |
| dan10101 |
Jul 22 2018, 09:20 PM
Ok here's the video you've all been waiting for. Well, a couple of you, ...at least one of you....
I finally got the BMW off the rack so i could put the Porsche on it and check it out from underneath. https://youtu.be/5pAHh21VGpw To answer Andrews question. I'm replacing a 2001 BMW 330ci that once looked like this. and now looks like this after going flipity flopety... |
| Rand |
Jul 22 2018, 10:06 PM
Cross Member ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,415 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None |
Just another opinion that's worth nothing, but to keep this true to the OG and put your touch on it... Keep the paint scheme and replace the highlights with YOUR color. Don't do a full color change.
| Mike Bellis |
Jul 22 2018, 10:39 PM
Looking at the video. You should buy a new tub. It will be cheaper in the long run just to transfer the drivetrain over. Look like you may need to replace from the doors forward.
Cheaper and faster to transfer everything into a good body. |
| dan10101 |
Jul 22 2018, 10:56 PM
Looking at the video. You should buy a new tub. It will be cheaper in the long run just to transfer the drivetrain over. Look like you may need to replace from the doors forward. Cheaper and faster to transfer everything into a good body. Unfortunately, this is on a budget that is likely to double before I even get started. The rear fenders are bonded to the tub. It would be near impossible to change those and too expensive start over. I'll make it work. My fall back is to go tube frame on the front and tie it into the roll cage. |
| dan10101 |
Jul 22 2018, 11:27 PM
Just another opinion that's worth nothing, but to keep this true to the OG and put your touch on it... Keep the paint scheme and replace the highlights with YOUR color. Don't do a full color change. Rand, Honestly, I'm leaning that way. But with the new information tonight about additional bodywork needed, It may take a full repaint. If that happens all bets are off. |
| Andyrew |
Jul 22 2018, 11:50 PM
That's about what I was expecting body wise. And one reason I keep saying we need to pull it out is to get that front end back into alignment and not just move sheet metal.
I see a straight donor chassis will leave you with not only good measurements to pull from but good steel. Even if you cut everything off and replaced I still think it needs some pulls to bring the tension out of the chassis. And once you have a good few pulls out you might find that it's not so bad. I'll give you a call tomorrow after work on my drive home. (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/welder.gif) (IMG:style_emoticons/default/wub.gif) |
| mgp4591 |
Jul 23 2018, 12:26 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,016 Joined: 1-August 12 From: Salt Lake City Ut Member No.: 14,748 Region Association: Intermountain Region
My new vote is for drug dealer green metal flake. Heavy 1070's disco speed boat metal flake. You will be unique and the only 914 ever painted this color. (IMG:style_emoticons/default/piratenanner.gif) Hell, put some 26" dubs on it too! (IMG:style_emoticons/default/aktion035.gif) Mike, I like you, but I sense that you've gone off on the whole what color will it be discussion. Did you imbibe in some gin and tonics early this afternoon? Actually, margaritas... (IMG:style_emoticons/default/first.gif) I get it. You're afraid if you go heavy metallic green you will get profiled as the old man king pin of the cartel. I understand... (IMG:style_emoticons/default/biggrin.gif) I thought it was DOPE!! Or maybe they just deal dope.... I get those confused... (IMG:style_emoticons/default/smoke.gif) |
| Cracker |
Jul 23 2018, 06:53 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,148 Joined: 2-February 10 From: Atlanta (area) Member No.: 11,316 Region Association: South East States
Congrats...welcome to the club.
Cracker |
| dan10101 |
Jul 23 2018, 02:20 PM
| Mike Bellis |
Jul 23 2018, 09:43 PM
Looking at the video. You should buy a new tub. It will be cheaper in the long run just to transfer the drivetrain over. Look like you may need to replace from the doors forward. Cheaper and faster to transfer everything into a good body. Unfortunately, this is on a budget that is likely to double before I even get started. The rear fenders are bonded to the tub. It would be near impossible to change those and too expensive start over. I'll make it work. My fall back is to go tube frame on the front and tie it into the roll cage. Long term the cheaper route is a new tub. It's also faster to completion. You can pull and push yourself but eventually it will need to go on a frame bench. To do that you have to remove all the suspension and drivetrain. You have to do this with a new tub as well. No loss in time or money yet. But the frame bench will cost you the same as a tub. Frame straight still needs a bunch of welding and patch panels. A good tub needs less work(=less money). Paint is the same cost. The sheridan body will cost you but you already need a front end. You would have to buy the rear stuff. End result is a better chassis for about the same cost +/-... Plus you could have the entire unibody slightly tweaked. Look for the thread when Sir Andy corner balanced his bent tub. One wheel was all jacked up in the air. All due to a slight bend in the unibody. He had to cut his cage out to fix it. Rapid deceleration (wreck) moves metal all over the place and you might not see it. Think long term and not short term payouts. I know you are dying to carve corners in this thing but if it's unstable at speed because it's bent, it could be your last drive... |
| dan10101 |
Jul 23 2018, 09:53 PM
Well, you're full of cheery thoughts...
| Mike Bellis |
Jul 23 2018, 11:38 PM
| Cracker |
Jul 24 2018, 06:25 AM
Ha! Definitely too many (at once) with my space limitations!
Regarding your project - I too have some thoughts. I am not trying to be a "Debbie Downer" but I also would not want you to kill yourself in an ill-handling car! I would encourage you to strongly consider all of your options before doing anything but parking your car in the garage at this point. For what its worth, which is probably not much, I am more than happy to discuss what I have learned over the years with you - PM me your contact info if interested. My experience with adding substantial power to a teener and the challenge of making the package work properly leads me to believe a new chassis would be the best decision (at least to strongly consider). From what I have seen over the years, your car was never finely tuned to adequately perform - not a poke - just reality. Repairing the chassis, as Mike has stated, would require a precise and enormous effort with no guarantees of the desired result. I realize all of these projects have "budgets" but to me - you essentially purchased a drivetrain - not so much a car. If I were in your shoes, I would have budgeted for a newly prepped chassis with a cage that ties into the windshield frame (A-pillar). Once a 914 has over 400 hp (and more importantly torque), the benefit of further strengthening the very weak center section of the car is paramount. Night and day difference in my experience - I have gone both ways on a few different teener projects. As a few can attest, a properly balanced build will pay huge dividends in the end. My car for instance, is remarkably tame and balanced with a good margin of increased power beyond your project. A teener can be built to be both a monster and pussy cat but it just doesn't happen throwing parts together. Best wishes! Cracker That's, hmm quite a stable you have there... |
| My 914 |
Jul 24 2018, 07:53 AM
Casual Member ![]() ![]() ![]() Group: Members Posts: 560 Joined: 23-April 16 From: Massachusetts Member No.: 19,928 Region Association: North East States |
| ValcoOscar |
Jul 24 2018, 08:15 AM
Garage Life ![]() ![]() ![]() ![]() Group: Members Posts: 2,677 Joined: 19-November 13 From: SoCal Member No.: 16,669 Region Association: Southern California
Having a V8 914 in the past, I also agree with Tony.
It's obvious that you have some solid feedback from some knowledgeable experienced members here. You have a lot of thinking to do. (IMG:style_emoticons/default/idea.gif) I understand budget constraints but I have never finished a car within budget. Shit happens and Murphy rears his head at every opportunity. In either case, you purchased a sweet project, just relax and enjoy the journey. I'm looking forward to what you decide. Oscar |
| dan10101 |
Jul 24 2018, 10:15 AM
Thanks for all your thoughts, but enough talk about body swaps. You guys are really bringing me down.
There is so much work done to this body/chassis, I just don't want to start over. This car is fixable. And it will be right when its done. All that said, I am getting a donor car. And I've ordered my Sheridan front end. Things could change as I get down the road a bit as the car itself will determine how the repair is done. I just need it to talk to me a bit, right now I think it's still in shock... |
Lo-Fi Version | Time is now: 4th September 2026 - 06:44 PM |
