Alternative to Gates Green Stripe hose? |
Mueller |
Jul 5 2018, 10:26 PM
Almost $200 for 50' of 1" ID hose? ouch!
mgp4591 |
Jul 6 2018, 02:42 AM
914 Guru Group: Members Posts: 5,380 Joined: 1-August 12 From: Salt Lake City Ut Member No.: 14,748 Region Association: Intermountain Region |
Almost $200 for 50' of 1" ID hose? ouch! The trick is to find someone to split a shipment with you because the Green Stripe is the best way to go from what I've heard. That's why I had no problem splitting an order with Chris in Vegas for my share. You may wait a little bit but put the feelers out there now and you might get lucky sooner than later. |
mb911 |
Jul 6 2018, 05:55 AM
914 Guru Group: Members Posts: 6,871 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
What does the green stripe lool like? I might be interested in some of this..
Chris H. |
Jul 6 2018, 06:42 AM
Senior Member Group: Members Posts: 4,031 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest |
Here it is for $2.15/foot Mike. It's labeled "boat heater hose" but it's the same stuff.
1" Gates Green Stripe You thinking about a conversion? |
Costa05 |
Jul 6 2018, 08:16 AM
Member Group: Members Posts: 320 Joined: 27-October 16 From: Phoenix, Arizona Member No.: 20,535 Region Association: Southwest Region |
Best I found so far for 1-1/4" gates green strioe in 10 foot sections is $136 ea. It is labeled as 2 ply radiator hose with wire impregnated. Also looking at alternatives. Suby conversion.
Lo-Fi Version | Time is now: 2nd June 2024 - 01:16 AM |
