Diagnosing D-Jet Problem...solution & update, All of a sudden...loss of power... |
MikeInMunich |
Jul 6 2018, 08:13 AM
Member Group: Members Posts: 392 Joined: 19-November 13 From: Munich, Germany Member No.: 16,674 Region Association: None |
Greetings once again from Munich gentlemen! (IMG:style_emoticons/default/bye1.gif)
It started with a thought and no wood to knock on, seriously! (IMG:style_emoticons/default/mad.gif) I was driving around Munich about 6 weeks ago and thought to myself, this car is running perfectly and needs nothing. What could go wrong? Then literally, less than a few minutes after that, it started. A light hesitation in the lower RPM range. Seemed like the car was choking a bit, or missing on once cylinder. I was at a D-Jet workshop last year with Dr. D-Jet. See https://oldtimer.tips/de/ Volker is a great guy and knows as much about this system as anybody. He tested the vacuum on my MPS last year and informed me that it was "borderline". So that was the main culprit. I took it out, sent it to him and this year it was indeed worse and thus the main culprit. Volker disassembled it and replaced the copper diaphram. Now it's tight like new. Some may be surprised that this is possible and / or where he got a new diaphram from. He had them manufactured or perhaps, I'm not sure, manufactured them himself. PM me if you want / need one and I'll send you his email address. So, with my restored MPS I hooked it up and, low and behold, the problem was quite the same, only about 10x worse! (IMG:style_emoticons/default/hissyfit.gif) Now, with the car immobile and Volker hundreds of km away, I'm practically on my own, with his and your advice, to try to track down the real problem. Volker thinks that because the MPS was operating sub-optimally previous to my purchase of the car that the mechanic or the P.O. had compensated elsewhere to get the car to run properly and that now that the MPS is sending a different signal to the CPU, things are off. More info: Just before the problem started my milage was really bad The CPU is the correct one for my MPS and working according to specs. Volker tested it. Engine has about 5,000 miles on it. Was rebuilt and running GREAT. Fuel pressure was set at 29 psi only about a year ago. I reckon it could have hardly changed on its own since then. (IMG:style_emoticons/default/idea.gif) The engine was originally a 1,7 but is now 2liters with a “proper FI performance Webcam” (as stated by the mech ic who rebuilt the engine) No adjustments were made to the FI to get it to run properly. It was running excellentwith a virtually perfect idle when warm and just slightly rough for the first 3 Miles or so. TPS plate and air temp sensor are new. What do y'all reckon could be the culprit? What should I be testing? I'm taking it to a place to tell them what to test, including: Fuel Pressure Plugs Compression CO value TPS setting Timing & dwell search for Vacuum leaks grounds Valve adjustment Fuel filter Relais Injectors... What else should I have them look for? Thanks for your input! With best regards from what was just ranked The Most Livable City in the World by Monocle Magazine, Mike in Munich |
Dave_Darling |
Jul 16 2018, 11:44 AM
914 Idiot Group: Members Posts: 14,982 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
A wide-band O2 meter would be a decent way to get real-time readings of the mixture. That way you could confirm that it is too lean.
--DD |
DRPHIL914 |
Jul 16 2018, 11:53 AM
Dr. Phil Group: Members Posts: 5,766 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
A wide-band O2 meter would be a decent way to get real-time readings of the mixture. That way you could confirm that it is too lean. --DD (IMG:style_emoticons/default/agree.gif) -- pretty sure I said that on post #19 (IMG:style_emoticons/default/poke.gif) - Got mine from Summit Racing, had the O2 bung welded in to the proper place on the Triad and ran the line for the gauge - WOW was I lean- and when the diaphragm on theMPS went bad before it went all the way I knew it was going because I was very rich suddenly- anyway - you wont be guessing--- Phil |
Lo-Fi Version | Time is now: 6th May 2024 - 11:21 AM |
