Annoying grinding noise after new pads |
andreic |
Jul 6 2018, 04:36 PM
Member Group: Members Posts: 172 Joined: 21-December 15 From: Madison, WI Member No.: 19,479 Region Association: Upper MidWest |
I installed new brake calipers and pads in the front on my 1.7L 914 (1972) after I discovered that one of the calipers was sticking. The calipers were high quality rebuilds from PMB.
Now I have this super annoying grinding noise whenever the car is moving. The noise is like something is grinding against the pads. It is there no matter if I press on the brake (hard or soft or at all), but it gets a bit louder if I step on the brake. I suspect that the new pads are a bit wider than the old ones. When looking at my disks again today I noticed that there is some surface rust on them, about the first 1/4" both from the outside edge and from the inside. I know I should have had my brake disks turned when I changed the calipers, but did not do it. My question is: will this annoying noise go away with a bit more driving, after the pads wear out a bit, or do I need to remove the calipers again, take the brake disks off to be turned, and reinstall everything? Sorry for the low quality pic... |
Spoke |
Jul 6 2018, 05:53 PM
Sounds like you went top shelf with restored calipers from Eric with new pads. Those rotors should be replaced with new ones. I wouldn't turn any rotor these days as new rotors aren't that expensive and turned rotors are now that much thinner.
Replacing rotors also gives a good look at the bearings too. Maybe replace those as well and have all new rotating and brake components up front. |
porschetub |
Jul 6 2018, 08:54 PM
Sounds like you went top shelf with restored calipers from Eric with new pads. Those rotors should be replaced with new ones. I wouldn't turn any rotor these days as new rotors aren't that expensive and turned rotors are now that much thinner. Replacing rotors also gives a good look at the bearings too. Maybe replace those as well and have all new rotating and brake components up front. Let the pads bed in to the rotors or if not in spec replace them ,can't remember the wear limit think its like just over one millimeter from new thickness...don't quote me. A lot of folks are unware the small amount the calipers move toward the disk,the piston seals dictate that. I'am never to fussed about decent worn solid rotors with a pad replacement but vented ones are a safety issue cause they can fall in half (IMG:style_emoticons/default/sad.gif) . Recently did all the disks and pads on my Audi now that is not cheap ,not much left from 900NZD fitted ,a powerful/heavy car the 914 couldn't be more different. |
HalfMoon |
Jul 7 2018, 08:09 AM
Senior Member Group: Members Posts: 828 Joined: 13-November 12 From: Shenandoah Junction, WV Member No.: 15,144 Region Association: MidAtlantic Region |
Venting clearances set, right?
PanelBilly |
Jul 7 2018, 08:39 AM
914 Guru Group: Members Posts: 5,799 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
I’ve always taken new rotor to the machine shop and had them turned first. I figure it’s best to start with a straight surface and I do t think you get that out of the box
rhodyguy |
Jul 7 2018, 09:55 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,070 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
More often than not, the rotor runout is less than minimum spec after turning. Redo...with new bearings. Then you can forget them til next time.
Chris914n6 |
Jul 7 2018, 11:47 AM
Jackstands are my life. Group: Members Posts: 3,305 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
I once picked up an early 911 that just had brakes done, by a reputable shop. Grinding the whole way home. Found one of the pads was put in backwards....
Jeff Hail |
Jul 7 2018, 12:49 PM
Senior Member Group: Members Posts: 1,141 Joined: 3-May 07 From: LA/ CA Member No.: 7,712 |
Double check the pushrod adjustment from the pedal to the master cylinder. The pushrod nose should have 0.040 (1mm) between the m/c piston. Rock the brake pedal back and forth gently, should have tiny bit of movement. If no movement rod is too long, excessive its short.
porschetub |
Jul 7 2018, 05:04 PM
porschetub |
Jul 7 2018, 05:08 PM
I once picked up an early 911 that just had brakes done, by a reputable shop. Grinding the whole way home. Found one of the pads was put in backwards.... (IMG:style_emoticons/default/WTF.gif) ha ha did that once but only had myself to blame ,my wife needed her car in a hurry and I rushed the job . |
andreic |
Jul 12 2018, 06:02 PM
I don't know, maybe I had a bad day and I put the pads in backwards. But I don't think I had such a bad day to put them in backwards on both wheels... Still, I'll check tomorrow.
(The car makes the same exact noise when spinning either the passenger or the driver's side wheel...) |
mb911 |
Jul 13 2018, 05:36 AM
914 Guru Group: Members Posts: 6,816 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
Its gotta just be the built up rust on the rotors. It will go away with driving a little bit.. Same thing went on with my sons 944.
HalfMoon |
Jul 13 2018, 08:06 AM
Venting clearances set, right? No ventin clearance for the front ,Jeff made a valid point about the cylinder pushrod I didn't think about that,mine was wound off and I needed to remove play in the pedal even with new disks and pads perfect now. Opps. Duh me. Now I see he had said it was a front pad replacement. |
Lo-Fi Version | Time is now: 30th April 2024 - 11:31 AM |
