Identify Cam Without Splitting Cases, 2.0 Liter 4 |
motorvated |
Jul 9 2018, 08:51 AM
Member Group: Members Posts: 279 Joined: 13-February 13 From: Colorado Member No.: 15,519 Region Association: Rocky Mountains |
Is it possible to determine what cam is inside the 2.0 liter four cylinder motor I just purchased, without splitting the cases. Can a dial gauge on the rocker arms and degree wheel on the flywheel be used to measure the cam lift and profile. Are any cam markings visible without splitting the cases. The engine was last run with carbs, but no history of whether or not the cam was ever changed. I'd prefer not to disturb the bottom end if possible. Tried a search, but couldn't find anything.
injunmort |
Jul 9 2018, 09:24 AM
Senior Member Group: Members Posts: 1,024 Joined: 12-April 10 From: sugarloaf ny Member No.: 11,604 Region Association: North East States |
I have been told the easiest way is to remove oil pump, examine the drive gear mounting. if it is riveted to cam, probably stock. if it is bolted, the cam has been replaced.
TheCabinetmaker |
Jul 9 2018, 11:04 AM
I drive my car everyday Group: Members Posts: 8,300 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Exactly like Mort said
Mark Henry |
Jul 9 2018, 11:33 AM
If it's bolted (aftermarket) most cam grinders stamp a grind code on the pump drive area of the cam.
Dave_Darling |
Jul 9 2018, 04:58 PM
914 Idiot Group: Members Posts: 14,982 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
And of course you can put a dial indicator on a pushrod or a lifter (if you can get access) or a rocker arm and use a degree wheel on the crank. It can be tough to match those measurements up with published info, though.
--DD |
motorvated |
Aug 24 2019, 12:21 PM
And of course you can put a dial indicator on a pushrod or a lifter (if you can get access) or a rocker arm and use a degree wheel on the crank. It can be tough to match those measurements up with published info, though. --DD Updating an older thread. Just pulled the oil pump off of the 2.0 liter motor to see what cam might be in it. Here's what I found. Looks like the oil pump drive is riveted on and not bolted, so am I correct to assume that the cam is most likely the original D-Jet fuel injection cam. Since the motor came to me with a set of 40IDF Webers, which I would like to use on this motor, is it time to split the cases and drop in a more carb friendly cam. Or can I run the carbs with this cam without leaving too much performance on the table. I also could swap over the L-Jet that currently is on the 1.8 Liter motor that currently is in the car, if the cam is compatible with that. Or I guess I could source a D-Jet set-up and bolt that on. I have been racing with various vintage clubs and SCCA with the 1.8, and would like to move up in the field a little with more power while staying at or below the 2.0 liter displacement limit that some clubs have. And I'm not looking for a killer race motor, just about 20 more hp than I have now. I'm apprehensive about splitting the cases, and maybe I shouldn't be. Any and all recommendations for a path forward with this motor will be appreciated greatly. |
JFJ914 |
Aug 24 2019, 12:51 PM
Senior Member Group: Benefactors Posts: 813 Joined: 13-June 03 From: Alpharetta, GA Member No.: 814 Region Association: South East States |
And of course you can put a dial indicator on a pushrod or a lifter (if you can get access) or a rocker arm and use a degree wheel on the crank. It can be tough to match those measurements up with published info, though. --DD Updating an older thread. Just pulled the oil pump off of the 2.0 liter motor to see what cam might be in it. Here's what I found. Looks like the oil pump drive is riveted on and not bolted, so am I correct to assume that the cam is most likely the original D-Jet fuel injection cam. Since the motor came to me with a set of 40IDF Webers, which I would like to use on this motor, is it time to split the cases and drop in a more carb friendly cam. Or can I run the carbs with this cam without leaving too much performance on the table. I also could swap over the L-Jet that currently is on the 1.8 Liter motor that currently is in the car, if the cam is compatible with that. Or I guess I could source a D-Jet set-up and bolt that on. I have been racing with various vintage clubs and SCCA with the 1.8, and would like to move up in the field a little with more power while staying at or below the 2.0 liter displacement limit that some clubs have. And I'm not looking for a killer race motor, just about 20 more hp than I have now. I'm apprehensive about splitting the cases, and maybe I shouldn't be. Any and all recommendations for a path forward with this motor will be appreciated greatly. I'm sorry to be a buzzkill, but right off the bat a 20HP gain is a minimum of $5,000 away. There is no shortcut to power in these engines. Oh, yes that looks like a stock cam. All of your induction choices will work, none will increase HP by themselves. Sorry |
motorvated |
Aug 24 2019, 01:06 PM
And of course you can put a dial indicator on a pushrod or a lifter (if you can get access) or a rocker arm and use a degree wheel on the crank. It can be tough to match those measurements up with published info, though. --DD Updating an older thread. Just pulled the oil pump off of the 2.0 liter motor to see what cam might be in it. Here's what I found. Looks like the oil pump drive is riveted on and not bolted, so am I correct to assume that the cam is most likely the original D-Jet fuel injection cam. Since the motor came to me with a set of 40IDF Webers, which I would like to use on this motor, is it time to split the cases and drop in a more carb friendly cam. Or can I run the carbs with this cam without leaving too much performance on the table. I also could swap over the L-Jet that currently is on the 1.8 Liter motor that currently is in the car, if the cam is compatible with that. Or I guess I could source a D-Jet set-up and bolt that on. I have been racing with various vintage clubs and SCCA with the 1.8, and would like to move up in the field a little with more power while staying at or below the 2.0 liter displacement limit that some clubs have. And I'm not looking for a killer race motor, just about 20 more hp than I have now. I'm apprehensive about splitting the cases, and maybe I shouldn't be. Any and all recommendations for a path forward with this motor will be appreciated greatly. I'm sorry to be a buzzkill, but right off the bat a 20HP gain is a minimum of $5,000 away. There is no shortcut to power in these engines. Oh, yes that looks like a stock cam. All of your induction choices will work, none will increase HP by themselves. Sorry The 20 Hp increase I am looking for is from the starting point of 82 Hp the current 1.8 liter motor was claimed to be making at sea level when new. I think a stock 2.0 liter makes close to 20 Hp more than that. So I'm not looking to get 20 Hp more out of the 2.0 liter. Thanks for your comments wrt the cam and the induction choices. |
Superhawk996 |
Aug 24 2019, 05:03 PM
914 Guru Group: Members Posts: 5,779 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Nope. 2.0L (stock) is more like 95HP. But a 10HP bump on an 84HP baseline feels mighty good.
Lo-Fi Version | Time is now: 6th May 2024 - 07:59 AM |
