Identify Cam Without Splitting Cases, 2.0 Liter 4 |
motorvated |
Jul 9 2018, 08:51 AM
Member Group: Members Posts: 281 Joined: 13-February 13 From: Colorado Member No.: 15,519 Region Association: Rocky Mountains |
Is it possible to determine what cam is inside the 2.0 liter four cylinder motor I just purchased, without splitting the cases. Can a dial gauge on the rocker arms and degree wheel on the flywheel be used to measure the cam lift and profile. Are any cam markings visible without splitting the cases. The engine was last run with carbs, but no history of whether or not the cam was ever changed. I'd prefer not to disturb the bottom end if possible. Tried a search, but couldn't find anything.
Mark Henry |
Jul 9 2018, 11:33 AM
If it's bolted (aftermarket) most cam grinders stamp a grind code on the pump drive area of the cam.
Lo-Fi Version | Time is now: 28th May 2024 - 01:46 AM |
