123 Ignition Vacuum Adv, Learn me on some vacuum |
nditiz1 |
Jul 11 2018, 06:59 AM
Senior Member Group: Members Posts: 1,177 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region |
Ok so I'm currently running the 123ignition dist on my 2056 with dual webers. I read the instructions and don't understand the mapping. I also don't know how it all works together. Can someone educate me on the vacuum adv and what curve would be best? As the rpm's increase it creates more vacuum thus creating more adv, but if I already have a curve setup to go from 12 degrees at idle to 28 degrees at 3000+ will the vacuum adv move the timing even higher once it is hooked up and mapped?
nditiz1 |
Jul 12 2018, 06:04 PM
The whole reason behind the want to use vacuum adv with the standard curve on the 123 is due to my webers having a lean hole. John from aircooled.net seems to think if I have more advance at light throttle (transition between idle and main circuit) then it wont lean out. I have several different jets and have tried several different combinations to fix this lean hole. The best one has been setting the idle to a 55, but then I'm running real rich. Also it only allows for a 1/4 turn out on the mixture screw for highest idle. If I have more advance during the transition it should help with the "leaning out" Correct me if I'm wrong here.
Lo-Fi Version | Time is now: 19th April 2024 - 11:11 PM |
