Yet another alternator question |
ThePaintedMan |
Jul 11 2018, 08:36 AM
Advanced Member Group: Members Posts: 3,885 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States |
Sorry for asking one that I'm sure has been answered before. Searched but couldn't find a thread that sounded quite like my issue. Getting ready for a track day next week, and of course having charging issues. Typically I see the alt light come on with ignition on, but it shuts off as soon as I start the car. Occasionally it does come on when I turn the ignition on, but the next time it doesn't. Now, it doesn't come on when the ignition is on or when it's running. I suspect it isn't charging regardless because I see 12.2 volts with the car off and about the same while it's running. The car has been sitting but it was charging prior to this and it was covered with one of Perry's excellent covers. I wonder if the brushes are bad, but I think it sounds more like a bad relay board.
dr914@autoatlanta.com |
Jul 11 2018, 02:33 PM
914 Guru Group: Members Posts: 7,827 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
relay boards do not go bad that often, and have not had one affect the charging system, I would substitute the voltage regulator second after making sure the belt is tight. Also make sure that the battery neg cable is cleanly attached to the right firewall and battery terminal. 914 alternators do not fail that often. Even if the bulb on the dash is bad it will not prevent the alternator from charging.
Sorry for asking one that I'm sure has been answered before. Searched but couldn't find a thread that sounded quite like my issue. Getting ready for a track day next week, and of course having charging issues. Typically I see the alt light come on with ignition on, but it shuts off as soon as I start the car. Occasionally it does come on when I turn the ignition on, but the next time it doesn't. Now, it doesn't come on when the ignition is on or when it's running. I suspect it isn't charging regardless because I see 12.2 volts with the car off and about the same while it's running. The car has been sitting but it was charging prior to this and it was covered with one of Perry's excellent covers. I wonder if the brushes are bad, but I think it sounds more like a bad relay board. |
Lo-Fi Version | Time is now: 1st May 2024 - 10:42 PM |
