Refreshing Front Fan Box, Refreshing Front Fan Box, Where to get Parts |
Highland |
Jul 11 2018, 04:30 PM
Senior Member Group: Members Posts: 512 Joined: 8-August 11 From: San Diego, CA Member No.: 13,418 Region Association: Southern California |
So, does anyone have a source for the material sandwiched between the 2 plates that make up the valve in the front fan assembly?
bbrock |
Jul 11 2018, 04:47 PM
914Rubber has them. They have nice kits for complete air box refresh.
Mikey914 |
Jul 12 2018, 10:43 PM
The rubber man Group: Members Posts: 12,649 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
https://shop.914rubber.com/914-Airbox-rebui...m?categoryId=-1
Here’s the one without the grill. It includes the large seal, the flapper seals and new top seal. Also have grills and improved grill seal. Attached image(s) |
Mikey914 |
Jul 12 2018, 10:45 PM
Also the grill seal is molded
Cheapest to add to the grill to the seal if you want both. https://shop.914rubber.com/914-Fresh-air-box-top-seal-SEAL-ONLY-Late-for-use-with-grill-914FAS.htm?categoryId=-1 Attached thumbnail(s) |
defianty |
Jul 13 2018, 01:52 AM
Senior Member Group: Members Posts: 659 Joined: 9-August 06 From: Essex, UK Member No.: 6,621 Region Association: None |
I've just finished my air box with 914Rubber parts. They fit perfectly.
(IMG:http://www.914world.com/bbs2/uploads_offsite/s6.postimg.cc-6621-1531468325.1.jpg) |
Mikey914 |
Jul 13 2018, 10:21 AM
Nice,
Would you mind if I use your picture, it's better than mine (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 3rd May 2024 - 08:30 AM |
